    Default Unknown button on 09 sierra slt crew cab
    On drivers door, there is a button between the 1 and 2 buttons for the seat memory. Please help. what is this button? Manual shows it but does not describe what it does.
    I think it has an arrow going up.
    thanks
    Larry
    I believe that this is the Easy Exit Seat button. The control for this feature is located on the driver’s door panel between buttons 1 and 2. With the vehicle in PARK (P), the driver’s seat exit position can be recalled by pressing the exit button. You will hear a single beep, and the driver’s seat will move back. If the easy exit seat feature is programmed in the Driver Information Center (DIC), automatic seat movement will occur when the key is removed from the ignition. See “EASY EXIT SEAT” under DIC Vehicle Customization (With DIC Buttons) on page 3-76 for more information. The memory seat and easy exit features can also be programmed using the DIC. For programming information, see DIC Vehicle Customization (With DIC Buttons) on page 3-76. This can also be found on page 1-10 of your owner’s manual. If you have further questions, please feel free to contact me directly. Thank you.
    Tricia, GM Customer Service.
    X2 on easy exit button. I have one too. Lowers the seat and pushes it back to make it easy to climb in & out.
    Ext Cab 4wd LT
    Check out my garage
    http://www.NStarWindow.com
  1. Sierra silverado 1999 2000 2001 2002 button 4wd switch
    Last: 03-11-2011, 11:30 AM
  2. Sierra silverado 1999 2000 2001 2002 button 4wd switch
    Last: 02-09-2011, 07:10 AM
  3. Sierra silverado 1999 2000 2001 2002 button 4wd switch
    Last: 01-09-2011, 10:10 PM
  4. Replies: 0
    Last: 02-10-2010, 04:05 AM
  5. 2008 Chevy Silverado Crew LTZ - Unknown Buttons on the Inside
    By wastedtxn in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-26-2008, 01:48 AM
