GM Truck Club
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Sr. Apprentice
    Feb 2007
    Deep South, USA
    Quote Originally Posted by Dj Friction View Post
    BruceB....
    I don't think that a shop directly charges more for a van...They work on flat rate for the job performed on a particular vechile......Now with that said.....certain jobs.....many those under the hood might well book more hours because of the diffucilty of the task of working on a van?
    Brakes on the such would be the same, tune-up, Alt's ,starter might well cost more.
    If that makes sense !!!
    Yeah, makes perfect sense. I like the vans but I probably shouldn't get one.
  2. #12
    Newbie
    Jun 2008
    Camuy, Puerto Rico USA territory
    Default taredown!!!!!!!!!!!!!!!
    you have to remove all the front parts,bumper, grill, headlights , front facing (where radiator is installed) the engine it's pulled through here
  3. #13
    Jr. Engineer Rumpamuro's Avatar
    Apr 2007
    Mississauga, Ontario (Canada)
    Quote Originally Posted by waldemar View Post
    I know someone else also said this, but its not always true, front end removal is more for mini vans, ventures, montanas, caravans, etc. i myself have done a couple on caravans and well its not that bad actually because the whole thing really just slides out after you get the bumper, rebar and rad out,
    the vans i think your talking about in this thread are more like astros, and full size contractor vans, on those you drop the engine from the bottom by taking out the subframe, there not too bad. even the tune ups there not as bad as people say, take out the doghouse, jack up the truck and take off the tires, and you got decent access, think of it like this. The post about plugs on vans being a biatch was i think posted more towards minivans, now those, those are fun.
  4. #14
    Moderator
    Davandy's Avatar
    Jun 2005
    Haasdonk Belgium
    Mine isn't a minivan, but I can tell you it's a pain to replace the sparkplugs
    Peter Smet
    Haasdonk, Belgium
  5. #15
    Sr. Mechanic John W's Avatar
    Sep 2007
    St Peters, Nova Scotia, Canada
    When I was working I actually did a motor job on a full size Chevy van (ambulance conversion) without taking the engine out. Tough but doable. The first day it was out after the motor job it had a trip to Halifax from Port Hawkesbury in Nova Scotia. The attendants told me they made the trip in less than two and a half hours; 175 miles. They ran it for 4 years after that and had no problems. It was a 350. So for me the engine would have to be completely gone before I would remove it. I have taken some out to replace them by taking the bumper, grill,rad support, and rad out too but I would still do an in frame job if I didn't have the engine crane and such.
    2000 4x4 Ext. cab 5.3 Z71
    2009 Corolla
  6. #16
    Apr 2007
    Dont get me wrong Davandy, i would say its more of a pain than to do it on a pick up with the same motor, but thats the beauty of a van. Try the simple task of changing a fuel filter on a F*** E350 with a 7.3L diesel, i think id rather change plugs on your van than change that filter.
    Nice Van btw, what motor does it have, 350?
    --> Rocco "Rumpamuro"
    --> Apprentice Mechanic (Cars and Trucks)
    --> Mississauga, Ontario (Canada) eh!
    --> Vehicles on the driveway:
    -2008 GMC Acadia SLE AWD
    -2007 Silverado Classic Reg cab, long box.
    -2008 Pontiac Vibe (my dads fuel efficient way to go to work)
    -1996 Pontiac Sunfire GT
  7. #17
    Default engine swap
    I've owned a couple vans. You can get to the motor pretty easily on some vans. It seems like it always take me longer to do something on the van than I think it will . It's usually more time spent than $$ spent unless you are paying someone to do the work. To get to the motor on the Express you have to go from inside the van, there is no way to do anything from the front unless you plan on doing a lot of work. Once you pull off the inside engine cover you can see most of the motor. I think it is worth the extra hassle to own a van, but I'm biased towards vans anyway.
  8. #18
    Moderator
    Davandy's Avatar
    Jun 2005
    Haasdonk Belgium
    Quote Originally Posted by Rumpamuro View Post
    Ya it's the 350. I'm lucky that I have to change the plugs every 100000
    Peter Smet
    Haasdonk, Belgium
  9. #19
    I was wondering how hard it was going to be to swap engines! I figured I would have to remove the front grille, radiator lights and trim and rad support. I would rather not remove the fenders if I don't have to.
  10. #20
    Sr. Apprentice vannooch's Avatar
    Jul 2010
    Greensburg, Pa
    Well, I'll let you know. I recently toasted the 5.7 in my savana and will be changing it out to a 383 stroker.
    I haven't swapped engines on anything in a while, but I think that I'm up to the task.
    It looks to me like the grille, and everything behind, not the fenders. Probably have to jack it up and roll it forward to clear the frame, we'll see. I have had vans for awhile and the utility of a full size van is unmatched. I pull my 05 Kawasaki concours into it, hook up my 26' Hilo trailer to it with my fishing gear and 16 foot canoe on top and I'm ready for a couple of weeks at camp. Just recently hauled a 15' roll of carpet inside with the doors closed in the rain, that ain't happenin with a pick up. Won't own anything else, even if I have to work on it once in a while. Actually I haven't done much to it, a couple of distributor caps which is easy to reach. The spun bearing was probably my own stupidity, I was pushing it too hard on a long steep grade while towing the camper. High miles with the 5w 30 weight oil and high rpms is a recipe for disaster, learned an expensive lesson on this one but I am getting a major powerplant upgrade.
    2001 GMC Savana SLT
    John 8:31-32
Similar Threads
  1. Help pulling rotors
    By pmartin816 in forum Lifted & Offroad Suspension
    Last Post: 07-05-2010, 10:59 AM
  2. Pulling Codes...
    By Thunderchild in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 03-23-2010, 09:25 AM
  3. Pulling VSS
    By KAHruzer in forum Chevy C/K Truck Forum
    Last Post: 10-12-2009, 01:10 AM
  4. the best parts to add for getting the best mpg when pulling?
    By chevymon in forum Performance & Fuel
    Last Post: 05-12-2009, 07:23 PM
  5. T.B. Pulling to the right
    By miser01 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-06-2007, 10:32 PM
