Results 1 to 10 of 12
Thread: Bore 4.8 to 5.3
    Default Bore 4.8 to 5.3
    Has anyone bored a 4.8 to a 5.3? I was told it's the same block, but I've also been told that if I bored the 4.8 I would blow my block quick because the 4.8 was the worst engine Chevy made. has anyone done this? Did it do a lot?
    if i'm not mistaken, they're the same bore, just different stroke
    What is the difference between bore and stroke? I thought the 4.8 had 4.8 liters of what ever and the 5.3 has 5.3 liters of what ever. Doesnt that mean that the 5.3 is bigger because it has more liters in it? If it has the same block then where is the other .5 liters at? I just want my truck to be faster lol
    '07 Chevy Silverado Classic
    PERFORMANCE
    -K&N Intake
    -Air Raid Throttle Body Spacer
    -Thrush Muffler
    -Bully Dog Triple GT Programmer
    5.3L V8
    LOOKS
    -3" Spindle Lift
    -Tint
    -Blacked Out Rims
    -Blacked Out Taillights
    SOUND
    -2 Kicker CVT 12s
    -Rockford Fosgate 6.5"
    -500 Alpine Mono Block
    -Pioneer 6.5" Touch Screen
    -2 Boss Tweeters
    SOON!
    -3.73 gears
    X2 what Badbrad469 said, its the stroke that makes the diffeance. The 4.8 and 5.3 have a 96mm bore. They both can be bored to 99mm. The 4.8 has a 3.267 (83) stroke, the 5.3 has a 3.662 (92mm) stroke. If you bore a 4.8 to 99mm bore and add a 5.3 (92mm) crank you have a 5.7 (346 cu. in.) Add 2" intake valve to the heads and a LS1 cam, you basiclly have cast iron block LS1. Also the 5.3 and 6.0 share the same crank. The 4.8 and 5.3 have the same block, the 6.0 is a diffeant block. The 6.0 has a 4.00 (101.6mm) bore. Hope this info helps you fiquire out what you want to build.
    Thank you so much!!! That helped me a lot. that is definetely my next upgrade Would I have to tune it after i did all that?
    PERFORMANCE
    -K&N Intake
    -Thrush Muffler
    5.3L V8
    LOOKS
    -3" Spindle Lift
    -Tint
    -Blacked Out Rims
    SOUND
    -2 Kicker CVT 12s
    -2 Boss Tweeters
    SOON!
    -3.73 gears
    Yes you will most likely need a custom tune.
    Shiiiiiiiit. Thats more money lol
    PERFORMANCE
    -K&N Intake
    -Thrush Muffler
    5.3L V8
    LOOKS
    -3" Spindle Lift
    -Tint
    -Blacked Out Rims
    SOUND
    -2 Kicker CVT 12s
    -2 Boss Tweeters
    SOON!
    -3.73 gears
    Theres a book called How to Build High Performance Chevy LS1/LS6 V-8's by Will Handzel. Its printed by SA Design. You can fined it on-line or at a GM dealer part # 88958786. Its a great book, includes a truck section. Its a older book ownly goes to '04 but alot of the info still works on the newer truck. The books author,Will Handzell was at one time in charge of GM Performance. Read it from cover to cover it has a wealth of tech info about the LS series engines.
    Master Mechanic clgoch187's Avatar
    Aug 2010
    Gettysburg, Pennsylvania, United States
    Quote Originally Posted by Chad513 View Post
    just pour in few liters, it easy! lol.
    but seriuosly, if was me id get heads off a 5.3 and port em, and a FAST 102 mm tb/mani set up with a good cam.
    03 Silverado 1500
    285/75/16 BFG's
    2 Blaupunkt 10" vW1000 subs in Subthump box
    ProComp Level Lift & 3" rear blocks
    I heard if you reverse bore it to a 4.0 and install a tornado TB spacer you can pick up 10 mpg and 75hp.
    Really tho, I'd prolly just add some boost. I would think it would be easier and quicker than pulling the whole motor.
    2009 Silverado LTZ Z71 4x4
    ReadyLift 2.25" leveling kit
    285/65/18 Nitto Trail Grapps
    5%tint all around
    Plasmaglow Fire & Ice LED Bar
    6000k HID's Low and Fogs
    Black badges
  1. stock 6.0 bore size????
    By 00chevy53 in forum Performance & Fuel
    Last Post: 01-18-2011, 09:29 AM
  2. Replies: 0
    Last Post: 03-31-2010, 02:20 PM
  3. bore size?
    By jerrynino in forum Lifted & Offroad Suspension
    Last Post: 09-15-2008, 12:35 AM
  4. big bore throttle body
    By ponyexpress976 in forum Performance & Fuel
    Last Post: 05-12-2008, 12:21 PM
