    Default 2002 Suburban 4wd Driveshaft noise??? Away from home troubles!
    Hello everyone,
    I am away from home visiting a sick relative and I starting hearing a rattling metal noise under the truck. (93,000 miles) I checked the muffler and all was secure. The noise worsened so I went to a local muffler shop to find the issue. The noise only occurs when the vehicle is in motion. The mechanics said that the noise was from INSIDE the drive shaft. They said that I needed a shim kit and that there was an inch play in the rear differential. I have heard a slight whine from the rear pinion bearing for a while. Does this all make sense? They could not fix it and said the truck was find to drive home - 300 miles. What would the expense be to have this done.
    Sr. Mechanic
    kburb's Avatar
    May 2010
    Blythewood SC
    yea it does make sense and the diff could last for 10,000 miles or 10. i am not sure what the cost will be but expect 300 to 500 dollars as i do feel its more than just a shim kit.
    91 Suburban
    D44/14BFF w/Disc conv - Yukon 4:88's - Yukon Grizzly Lockers F/R -13" lift - DIY4x Shackle Flip - 37 ATZ on 18 MT Classics - Doug Thorley headers - Magnaflow - Holley Pro Jection Intake - Ultimate TBI mods - Hydroboost Brake Conversion - Hysteer-X Over Conversion.
    (Coming up - Fuel Injected 383 Stroker - Divorced NP205 - D60 - 40" tires)
    Thanks for the help.
    Got it fixed. Turned out to be a bad rear universal joint. Replaced front and rear and the ride is great.
  1. Cyclical Grinding noise 5mph+ 2002 Suburban 1500
    By bjbubble in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-17-2010, 08:19 PM
  2. front driveshaft 87 suburban
    By socal77k5 in forum GM Powertrain
    Last: 06-17-2010, 11:06 PM
  3. 2002 silverado 4wd troubles.
    By kennifer in forum GM Powertrain
    Last: 02-25-2010, 10:48 PM
  4. 2002 Stereo troubles
    By sgtstatic in forum Audio, Video & Gadget Tech
    Last: 03-27-2009, 03:26 PM
  5. 2007 Suburban c 1500 Driveshaft +
    By ez g in forum GM Powertrain
    Last: 05-04-2008, 07:25 PM
