    Default trailer axle alignment
    I'm having an issue with my tent trailer "eating" tires. the shop said that I should just need to replace the axle (a "torflex" rubber torsion axle) as there is no allowance for adjustment and the axle is probably bent. I'm ready and able to replace the axle, but, before I lay down a few hundred dollars for a new axle, is ther a ready way a shadetree mech like me can check to make sure the axle is simply bent and not some other damage to the frame or other that is causing the alignment to be off.
    (Does that make sense?)
    I would think an alignment shop could put it on their rack and use the alignment machine to check if it's slightly bent beyond what can be seen with the naked eye.
    Christopher
    u need to pull a string from front to back ( center ) and then check both axles with an angle...need 90 degree everywhere and your fine ...i bet they are off, if only 1/4 inch off they will eat tires !
    hope that helps !
    Scott:glasses:
    Measuring from fixed points on both sides and comparing the numbers is about the only way I've ever heard of checking for bends on a single axle trailer
    Thanks for the help guys. I was hoping it would be as easy as applying a little geometry to the problem. I'll get some string and make sure it is square with the center line. and a few other measurements to make sure it is the axle that is bent.
    Thats it ! as long as the axles square with the center line... because it realy does not matter if a frame is bend on a trailer as long as they are square.
    If an axle is bent ( torsion axle ) u can heat it and bend it back easy..just not on the outer 12 inches....since this is where the rubber for the torsion is!
    Also , a new torsion xle is about 100-200 bucks only depending on size. Check trailerparts DOT com
    Scott:glasses:
  1. alignment specifications
    By reklessndn in forum Lifted & Offroad Suspension
    Last Post: 10-05-2010, 07:39 PM
  2. Alignment?
    By Ridinonacloud in forum General Chevy & GM Tech Questions
    Last Post: 08-08-2010, 03:59 AM
  3. Alignment
    By KAHruzer in forum Chevy C/K Truck Forum
    Last Post: 07-30-2010, 07:06 PM
  4. is a alignment needed?
    By Cuda1500 in forum Lifted & Offroad Suspension
    Last Post: 06-21-2010, 11:34 AM
  5. alignment issues
    By npverhey1 in forum Lifted & Offroad Suspension
    Last Post: 02-04-2009, 07:56 AM
