    Default Body molding on NNBS
    I was wanting to know how to get the body molding off my door panel. anyone done this? is it somethign they can do at dealership easier?
    2010 Chevy 1500 LT Z71 ext cab
    Line-X
    Cat back Flowmasters
    2" Zone lift
    goRhino dominator II step bars
    tinted windows
    BFG AT
    ARMY STRONG
    Quote Originally Posted by asu4cjustice View Post
    There are a Couple of Ways to Remove the Door Trim....I Did & Used the Following items,
    1. .....A Heat Gun.....to help Soften the Trim
    2. .....Fishing line Between the Body & the Trim......and in a Sawing Up and Down Motion
    3 .....Once I Removed Half of the Trim....I Gently Pulled the Remaining Trim Off
    4. .....I used a 3M Eraser Wheel to remove the left over Adhesive.....you could also Use Goo Gone to Remove the Adhesive
    5. ......Wash the Area down and Then a Coat of Wax
    6........Last Take your Time
    It just peels off. Its a little trickie getting started but just pull slowly. It WILL leave some 3M tape. You can get a 3M eraser wheel and 3M adhesive remover at most auto parts stores. Wash the area with soapy water to clean dirt that collects under the molding, than use the eraser wheel and finish with the adhesive remover, then wax area. If you don't like using the eraser wheel than you can peel off the tape after soaking with the adhesive remover. This does take alot of time and kills your fingers. Get the eraser wheel.
  1. Removing body molding
    By denn454 in forum Chevy Truck Accessories
    Last Post: 08-19-2012, 11:12 AM
  2. 2001 CHevy silverado ext cab 1500 Ls- Looking for side body molding
    By paul carr in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-11-2010, 01:59 PM
  3. Body Side molding
    By Prophet1990 in forum Chevy Truck Accessories
    Last Post: 03-18-2010, 07:20 PM
  4. Wanted: body molding
    By billinthehills in forum General Classifieds
    Last Post: 11-19-2009, 05:03 AM
  5. 04 Cab Molding
    By MBurke in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-22-2009, 08:03 AM
