    Default malfunctioning gauge pod. 98 k1500
    issue started last night, the all the gauges and lights in my gauge pod went dead. non of the gauges worked, my two turn signal indicator lights were on steady(off outside the truck), and my brights indicator was on(brights were off). this was all with the lights on. with the lights off the gauges only partially function, everything was lower then it should be. eg. i had almost a full tank, and it showed less that half.
    any suggestions as the the problem and the cure. i havent taken anytime to trouble shoot, but before i start id figure id ask, hoping someone has delt with it before.
    thanks,
    Dave
    98 Silverado
    5.7 vortec
    14 bolt posi rear, with 373s
    3"body?1.5"susp.
    33" wild countrys
    tube steps, chrome kit, fenderflares,
    chrome diff plate, window flares,
    2-10"Alpine TypeE, Alpine 450watt V-Power.
    alternator? I'd take it to a parts store and see if they can check your voltage reading. How old is the battery? Sometimes one or two ports can dry up and cause a simliar loss...
    would a voltage loss cause such a specific malfunction though? all other electrical/electronic systems seem to be working properly.
  1. Factory in-dash 6 disc changer malfunctioning
    By SlickMachine in forum Audio, Video & Gadget Tech
    Last: 07-17-2011, 03:14 PM
  2. 97-98 k1500 dash compatable with a 95 k1500?
    By Lifted_Bowtie in forum General Chevy & GM Tech Questions
    Last: 12-11-2010, 04:51 PM
    Last: 07-30-2010, 07:00 PM
  4. Oversize tires causing malfunctioning speedo
    By cowboytex98 in forum Chevy C/K Truck Forum
    Last: 06-05-2010, 01:17 AM
  5. Fuel Gauge vs Tank Capacity - 2002 K1500 5.3L
    By mikehd in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-10-2007, 08:37 PM
