    Apr 2011
    East Jordan, Michigan, United States
    Default Replacing instrument cluster lights and ac controls lights
    I was wondering if someone can tell me how you get access to those bulbs
    What year/ model truck? Typically what you do is remove the dash trim piece, undo the bolts holding the cluster in place, pry open the cluster and replace the bulbs.
    I need to replace several also. I have a 2004. Gauge cluster light is out. I have heard you have to solder the new ones in. Does anyone know what kind of bulb to replace them with?
    2004 Silverado 4x4
    2003 Suburban 4x4
    1968 Chevy Caprice- show room condition
    Apr 2011
    Hello my silverado is a 2006
    Unless Chevrolet has made a big change since 99, all you need to do is remove the trim bezel around the cluster, the cluster is held in by 4 screws, remove them and you will be able to remove the cluster. The lamp socket twist out and the buls pull out of the socket. The only ones I have seen that need soldering are the ones in the radio. Take your time and you will do fine.
    Unfortunately, the 03-07.5 NBS truck clusters have soldered-in incandescent bulbs like these---->http://cgi.ebay.com/ebaymotors/100-G...Q5fAccessories
    But the cluster removal is still the same procedure. Not sure about the climate control bulbs but I believe there might be a tutorial on replacing them in the How-To section of the forum.
  1. Instrument Panel Lights (some not working)
    By scarpint in forum Audio, Video & Gadget Tech
    Last: 01-27-2013, 11:30 PM
  2. instrument cluster lights
    By Kickerking817 in forum Lighting Discussion
    Last: 03-04-2011, 01:44 PM
  3. 2003 Yukon Instrument Cluter Lights/Radio Lights?
    By buzzsaw714 in forum General Chevy & GM Tech Questions
    Last: 11-07-2010, 07:53 AM
  4. 1994 silverado no instrument lights dash lights
    By woodslip in forum Audio, Video & Gadget Tech
    Last: 07-12-2009, 11:47 PM
  5. Instrument panel lights went out
    By johncc in forum General Chevy & GM Tech Questions
    Last: 10-01-2008, 08:56 AM
