Results 1 to 10 of 15
    Sr. Apprentice OHChevy03's Avatar
    Oct 2010
    Columbus, Ohio
    Default Cold Air Intake Vs Exhaust System
    I've had my truck for almost a year now and am looking into doing a mod or two. I was looking to hear some opinions on the benefits of both a Cold Air Intake and an Exhaust System on MPGs and HPs. I'm not looking to have an exhaust system that is extremely loud, just louder than stock (if I go that route). Also, I have heard that CAI can make the engine sound a little louder, is this true? Any comments are welcome.
    03 Silverado 5.3L 2WD Ext Cab LS, Summit White
    Cooper Discoverer S/T 265/75-16s
    Back Country Step Bars
    Daystar Leveling Kit
    A CAI and a better exhaust will give you an increase in HP and maybe a slight increase in MPG as well. However, don't expect a lot of gains from either upgrade by itself. When you have an intake, an exhaust and other upgrades such as headers or a custom tune all on your truck, you will see much bigger improvements than having just a single upgrade. A CAI might change the engine sound a little but idk.
    I had a cai on my 89, it sounded alittle but not as much as the exhaust
    1998 K1500 Ext. Cab 4.3 5spd
    Amsoil, CIA
    2007 Harley Davidson Vrod
    Amsoil, Vance & Hines 2into1, K&N Topless,
    Screamin Eagle Racetuner, StageII cams,
    Carbon fiber front fender, and a few more lil goodies:wink:
    It all depends on your foot... If you have a heavy one then you will not get better MPG's.. As for a good exhust with low noise Corsa would be a good one to look at.. Also what a lot of people over look if you are going to take your 5000LBS Truck faster look in to better breaks too...
    Quote Originally Posted by OHChevy03 View Post
    I just installed the Airaid MIT and it definitely is louder than stock. The reason why CAI works better than stock, or I should say one of them, is that the air path is simplified which means the removal of the resonators(pockets) that the stock intake tube has to reduce the sound.
    2007 Silverado VortecMAX R.I.P 24JUN2011
    2005 Honda VTX 1300R
    2008 Tahoe LTZ
    2009 Dodge Challenger R/T
    Oct 2010
    Columbus, Ohio
    Okay would it make more sense to leave the filter and filter box stock and just add a new, larger tube? Would this make the engine run more efficient? If I go this route along with a exhaust system would this improve HP and MPGs?
    I just installed a K&N Air Filter and dual exhaust's with a Flowmaster super 40 Series dual in / dual out and i can a good bit of difference from my straight's i had. I plan on installing a x pipe which will help me get a few extra HP and some torque and help the exhaust flow more evenly. I believe this will help some also and i will buy header's later on down the road but these mod's together you will see a difference...
    2008 Chevy Silverado Ext. Cab Lt Z71 5.3 V8
    7.5 Inch Rough Country Suspension Lift
    RBP Replica Grille Black w Chrome Rivets
    Recon Smoked Cab Roof Lights
    N-Fab Powdercoated Gloss black Cab Length Nerf Steps
    5% Tint over 20% all the way around / 5% Eyebrow Strip
    AVS Smoked Window Visors
    Z71 Stickers Black & Metallic Silver
    Tow Mirrors / Smoked Turn Signals
    XM Satellite Radio Fin / Color Matched
    Interior Plastic Pieces / Color Matched
    Power Acoustic Tweeters
    Painted Bowties / Color Matched
    Painted Door Handles / Color Matched
    Smittybilt Bull Bar / Color Matched
    Custom Rolled Edge Exhaust Tips / Color Matched
    Custom 2.5 Inch Cat Back True Dual Exhaust
    Flowmaster Super 40 Series Dual in / Dual out
    Magnaflow Tru-X Pipe
    K&N Air Filter
    18x9 Rockstars Machined Black
    Center Caps / Color Matched
    33.13.50 Nitto Terra Grapplers
    New Front Wheel Well Liners
    Eagle Eye Black L.E.D. Tailights
    Eagle Eye Black L.E.D. Third Brake Light / Smoked
    Eagle Eye Black L.E.D. Halo Projector Headlights
    Notto HID Kit 10,000k Low beams
    Recon L.E.D. Light Bar
    Buschwacker OE Style Tailgate Cap
    AMI Gloss Black Antenna
    Debadged Chrome Lettering
    Door Molding Removed
    I would recommend buying either the Airaid MIT and just get a drop in filter of whatever brand. Keep the OEM airbox as it is already basically a CAI. It is on my 2007 VortecMax 6.0L. Not sure if yours is.
    If you look at the sticky about CAI you will see that the stock air intake with just a k&n drop in filter performed about as good as all the other expensive CAI kits. Therefore reasonable deduction will tell you that basically a Airaid MIT or something similar will give you equal performance at a fraction of the cost. The Airaid MIT does make more noise than stock, but only when you are into the throttle heavy. At cruise I hear no more engine noise than with the stock setup.
    Now you have air coming in at a greater rate, thus you need to provide a place for it to go. Best solution would be long tube headers and an exhaust system. I am looking into Banks Monster Exhaust as I am going to stick with a 2-1 setup. I am not looking for a noise machine but just a more efficient intake and exhaust process. The more efficient you make it the better HP and MPG you get.
    Now my problem is that I like the new growl and the perceived pickup so my gas mileage has actually dropped. I went from 15.2 avg to 15.0 avg and I will say that I am giving it more throttle and goosing it more than I used to. So I will take a hit of only .2 mpg for now and when I get over the newness I'm sure I'll see a slight overall increase in mileage.
    2008 Tahoe LTZ
    Volant CAI and Gibson cat back exhaust, you won't be disappointed.
    Adam
    Master Mechanic
    KyleZ71's Avatar
    Jun 2010
    York and Wilkes Barre, PA
    If you wanna do exhaust I recommend these guys (my kit is on it's way). They will build the kit for your truck so you dont need to remove the spare tire. Right now free shipping and 10 percent off. http://www.truckexhaustkits.com/
    Objects in mirror are losing
  1. Cold Air Intake and Exhaust tips for 305 vortec
    By hammsfamms in forum Performance & Fuel
    Last Post: 03-29-2011, 12:32 AM
  2. Cold Air Intake, Exhaust, Tuner
    By dum160 in forum Performance & Fuel
    Last Post: 01-20-2011, 10:48 PM
  3. Cold Air Intake or Dual Exhaust
    By TexAg95 in forum Performance & Fuel
    Last Post: 02-09-2010, 06:19 AM
  4. Volant Cold Air Intake System
    By BLK-Z71 in forum General Chevy & GM Tech Questions
    Last Post: 08-27-2009, 08:24 PM
  5. best cold air intake system
    By ochs99 in forum General Chevy & GM Tech Questions
    Last Post: 07-19-2009, 04:48 AM
