    Aug 2006
    Wesley Chapel, Fl
    Default how to change throttle body gasket
    can anyone guide me through this? i am having such a hard time i never mess with the fuel system so i thought i'd ask someone on here...
    Before changing anything I would test it. I know this has to do with your high idle so here is an old school test, I love old school, low tech testing, ask anyone on here.
    With the engine running and the air cleaner off get a spray bottle, like an old Windex bottle. Fill it will plain water. Now spray around the bottom of the throttle body, where the gasket is. (you can also use starting fluid, but don’t).
    Now pay attention to the idle speed, if there is a leak at the gasket the idle will change, rise or lower depending on the problem.
    No change, no problem. If the idle changes then there is a problem. Get a gasket and change it. Just remember that a vacuum leak around the intake or a vacuum line can also cause an idle problem.
    I have had vacuum leaks in fuel injection systems cause all sorts of problems, from idle surges to no start.
    Once you are sure that you have vacuum leak, and where it is we will go about fixing it.
    I just don’t like throwing parts at a problem, test, test, test.
    And one Big Pain in the Ass When it Doesn’t.
    See a Pattern yet?
    I did this on my 89 305 1/2ton...but do you think I can remember. I think I remember undoing bolts out thru top gently work old gasket out (If it cracks careful not to drop gasket bits down into intake) and slipping gasket in underneath it cuz intake side looked clean (I didn't need to scrap gasket) I used to test for leaks using a propane cylinder turned on but not lit. Then I moved it around area in question tell idle came up. I could be leaking from some of the other hose too.
    Jamie
    Quote Originally Posted by Cableguy View Post
    Thank God you're still alive Jaime....That don't sound too safe or smart That's like looking for a gas or propane leak with a lit match lol
    Christopher
    He He He What like using ether to mount a truck tire....Now thats cool to watch!
    I used a little propane bottle with the extension hose on it....What eyebrows.... Who needs eyebrows...:sarcastic:
    LOL
    But it works.
    You may not be around to fix the leak after you find it.
    Thats why i didn't recomend the starting fluid test.
  1. lifter clacking after intake gasket change
    By runaway in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-23-2010, 05:46 PM
  2. 87 C10 Holley Throttle Body to Edelbrock gasket leaks
    By cyberpine in forum Chevy C/K Truck Forum
    Last: 02-04-2010, 04:32 PM
  3. Throttle Body
    By doublej in forum General Chevy & GM Tech Questions
    Last: 04-01-2009, 04:08 PM
  4. Throttle body
    By 97silverado430 in forum General Chevy & GM Tech Questions
    Last: 12-28-2008, 07:11 AM
  5. high idle..what else besides throttle body gasket
    By Big6ft6 in forum GM Powertrain
    Last: 08-23-2007, 08:58 AM
