    Newbie
    May 2011
    Western Massachusetts
    Default In need of a valve job
    my trusty '81 chevy c10 flatbed needs valve seals last time i did the seals on a small block v8 it took me 2 hours, does anyone have any tips/shortcuts that can save time?
    Thanks in advance
    Dave
    Sr. Engineer
    Oct 2010
    Indianapolis, In
    I have no shortcuts to offer but two hours is a little more than seven minutes a valve and that ain't to bad. Did you have the heads off or replaced them while still bolted on ? I have tried the rope in the bore trick and while it does work, it was such a pain that I just pulled the heads as I figured I was gonna screw up and have to anyway. Got a spare set of heads!? Good luck and let us know what you end up doing.
    They make a tool where you take out your sparkplugs and you screw in a hose connected to an air compressor. Doing so will hold the valves in place when the springs are off. I've done this when replacing the seals on my buddys 87' 350. Worked great. Take note that when you put the air pressure in the cylinder the engine might turn a little bit at first as the pressure pushes the piston down so be carfull of belts and pulleys.
    Hope this helps a little. Good luck!
    That tool works really well...
    1998 K1500 Ext. Cab 4.3 5spd
    Amsoil, CIA
    2007 Harley Davidson Vrod
    Amsoil, Vance & Hines 2into1, K&N Topless,
    Screamin Eagle Racetuner, StageII cams,
    Carbon fiber front fender, and a few more lil goodies:wink:
    Jan 2011
    Coeur d'Alene, Idaho, United States
    If you can't find the tool I had a boss in an auto shop that made one out of an old spark plug that he broke the ceramic out of and then brazed a hose fitting into to make one. This was back in 79 and I was amazed at how well it worked.
    1991 Chevy Suburban, 190K, 1500 1/2 ton, 5.7L, 3:42 gears, 4X4, stock tire size, stock suspension set up.
  1. Looking for egr valve pro.
    By paul logan in forum GM Powertrain
    Last: 09-20-2010, 10:39 PM
  2. Bad Valve?
    By AZ Suburban in forum GM Powertrain
    Last: 08-05-2010, 09:23 PM
  3. Where is the PCV valve on a 03 Silverado 5.3 ?
    By ibmoses in forum GM Powertrain
    Last: 07-11-2010, 07:32 PM
  4. pcv valve?
    By chazawazzle in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 01-13-2009, 08:20 PM
  5. check valve
    By abuelito in forum General Chevy & GM Tech Questions
    Last: 06-17-2008, 08:43 AM
