    Default Rubbing noise when rolling down driver side window
    Hi,
    I just bought an 08 Silverado and am noticing a rubbing/screeching noise when rolling down the drivers window. It happens when the window gets about halfway down and only for a quick second, but it is a little annoying. Could this be an easy fix or is it going to be a project?
    Thanks!
    Quote Originally Posted by eanderse View Post
    Hi,
    Thanks!
    Try cleaning the felt strip that the window slides against....some times dirt get trapped in there....its a good idea to clean it out anuway sionce the dirt can end up cutting ugly grooves in your glass.
    I have an 08 Sierra and I have noticed I am getting some noise maybe from the roller track becoming loose...I need to pop the door panel and take a look. Actually I have noticed all my windows are not as "tight" in the roller track anymore, however, this may something to do with the decibel level in my truck at times
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    I would also recommend cleaning the area around the window and seeing if this helps the noise. There is also the possibility that something has shifted and is causing the rubbing that you are hearing. In order to get a proper diagnosis for the concern, I would recommend contacting your local dealership. Please feel free to keep me posted. Thank you.
    Tricia, GM Customer Service.
  1. window not rolling down!
    By nickolas388 in forum GM Electrical Tech
    Last: 12-27-2011, 04:56 PM
  2. Side Window Repair Kit - Wind Noise!!
    By prats4 in forum General Classifieds
    Last: 02-08-2009, 07:38 PM
  3. 2004 Ext Cab rear side window noise
    By curtisjon in forum Chevy Silverado Forum (GMC Sierra)
    Last: 12-24-2007, 10:12 PM
  4. Driver Side Window Problem
    By ukrkoz in forum Chevy Silverado Forum (GMC Sierra)
    Last: 05-07-2007, 05:17 PM
  5. Problems with remote start and electric driver side window
    By surferboyyy in forum Chevy Colorado Forum (GMC Canyon)
    Last: 02-27-2007, 08:19 PM
