    Mar 2010
    Jacksonville, FL
    Question Tranny issue- 116K, newly rebuilt engine, and it 'bumps' like shifting at times....
    vehicle: 1999 Suburban 2500 4x4 gov't issue, 4L80E tranny, 350 Vortec- just rebuilt...and the tranny 'bumps' like it wants to shift hard but doesn't shift, usually in top gear. Also, every once in awhile, it 'shudders' like you're going over those highway 'wake up' strips on the edge of the road, but if I let off the gas and then hit it again, it stops....
    Any ideas on the issue here?
    Thanks,
    Stevo
    stephan's Avatar
    Far West, Oregon USA,
    I think what you're feeling is torque convertor chug or shudder. Some do it & some don't. If you get tired of it, try not to go through that rpm/speed so slowly when in top gear. It's not going to harm anything, it's just annoying.
    3" susp. lift kit "shadetree"
    Mar 2010
    Jacksonville, FL
    Is it possible that the fluid is too full? I just checked the level, and it's OVER what it should be...
    Stevo
    stephan's Avatar
    Hey Stevo, I've never heard of high fluid level causing TC chug but I suppose it's possible. How much too high is it & are you using the correct procedure to check the level?
    There's only 2 ways it can get overfull, if you put too much in it, or if your trans cooler in the radiator tank is leaking & exchanging coolant with trans fluid.
    Mar 2010
    Jacksonville, FL
    Quote Originally Posted by stephan View Post
    I had the engine rebuilt, and put too much in. Not sure how to check it properly. Nothing leaking, that's for sure....
    Stevo
    stephan's Avatar
    Quote Originally Posted by Stevodod View Post
    Stevo
    OK to properly check the level is with the engine & trans completely warmed up, & while idling in park on level ground. Just to make sure the trans is completely warmed up takes about a 1/2 hour of normal driving around. Pull the stick, wipe it off, reinsert it for a second & check it. If it shows overfull on the stick drain the extra out because when overfull it tends to make the atf foamy & the fluid may not work as designed like this.
  1. How to tell if an engine has been rebuilt
    By Michael Johnson in forum General Chevy & GM Tech Questions
    Last Post: 03-01-2011, 10:01 AM
  2. Question about rebuilt engine
    Last Post: 03-08-2010, 08:26 PM
  3. Tranny jumps rpms when shifting
    By bluestreak94 in forum General Chevy & GM Tech Questions
    Last Post: 12-07-2009, 01:50 PM
  4. Shifting issue
    By sindawg10 in forum GM Powertrain
    Last Post: 09-09-2009, 12:57 PM
