    Default 89 gmc 3500 cab & chassie shifting problems with th400
    only shifts up by moving stick shift between geers and nutral Shifts down normally
    stephan's Avatar
    Far West, Oregon USA,
    Hey Dano I'm guessing you have already checked the trans fluid level & it's ok. The next easiest thing to check is the vacuum line & hose to your modulator valve. The mod valve is located on the passenger side rear corner of the TH400. Make sure & check this line all the way to the engine to make sure there are no vacuum leaks or breaks in this line. Pull the hose section loose from the valve. If you find trans fluid in this hose then the diaphram in the mod valve is leaking. Even if there is no trans fluid, it could still be bad. At this point I would try a new modulator valve.
    If you aren't sure how long it's been since this trans was serviced & you want it to last, you should also pull the trans pan & check for general maintanence. See if the filter is clogged and/or if there is a lot of crud in the trans pan.
    3" susp. lift kit "shadetree"
    murdog94's Avatar
    Quote Originally Posted by stephan View Post
    X2 exactly where i would start...
    Mike
    Currently
    2011 F-150 Crew 4X4
  1. Transmission shifting problems..
    By JRD761 in forum GM Powertrain
    Last Post: 07-12-2010, 08:32 PM
  2. Down shifting problems
    By tate96 in forum Member Introductions
    Last Post: 02-24-2010, 06:46 PM
  3. 1st gear shifting problems.
    By Stellarex in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-01-2009, 08:32 AM
  4. 93' 1500 shifting problems
    By ftball2307 in forum GM Powertrain
    Last Post: 08-29-2008, 05:12 PM
  5. shifting problems - maybe the first sign of a necessary rebuild?
    Last Post: 08-12-2008, 10:29 AM
