    Default electrical issue
    i have a 1986 Suburban and one of the wires on one of the window switches was loose and it sparked and now i have no power to anything in the ignition. my headlights still work so it didn't kill all the power but i have no gauges, radio etc.. i checked all the fuses they are all good. any and all suggestions are welcome.
    stephan's Avatar
    Far West, Oregon USA,
    First I would fix the switch wire that sparked & make sure that's in order, (disconnect your negative battery cable first) then I would go back & check all your fuses on both sides with a volt meter if you have one, or with a test light if you don't.
    3" susp. lift kit "shadetree"
    all fuses are good. the wires going from the outside of the firewall look as well so i'm guessing it's something behind the fuse box or in the ignition?? i have no idea. electrical stuff can be so difficult at times if you don't know the source of the problem. it may just be one of those things i have dig for.
  1. electrical issue ?
    Last: 06-15-2010, 10:25 PM
  2. Trans electrical(?) issue
    By bigdogdaddy in forum GM Powertrain
    Last: 05-28-2010, 03:20 PM
  3. Electrical Power issue
    By ColonialRovers in forum General Chevy & GM Tech Questions
    Last: 10-06-2009, 09:20 PM
  4. electrical issue??
    By GReddy212 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 04-04-2009, 08:50 AM
  5. Audio troubles and electrical issue
    By hailey in forum Audio, Video & Gadget Tech
    Last: 02-03-2009, 07:56 AM
