    Default 2002 silverado HD 6.0 engine clicking
    Whats up guys, just got a new toy. 2002 silverado HD 6.0. Only 65k miles and garage kept. Its beautiful and its in mint condition in and out. Only thing is im getting a clicking sound coming from the engine, sounds like its coming from the bottom front of the engine. I literally just got this yesterday, and have not had the chance to see if it fades or stops as the engine is cold, warm, or at running temp. Sorry for the lil info, just trying to see if there is a widely known issue, my first silverado. Its not terribly loud but its not quiet either. Thank you for any feed back.
    Gorg
    ---------- Post added at 09:54 AM ---------- Previous post was at 09:52 AM ----------
    Sorry its a 1500 to.
    Welcome to the club, Gorg. Is your truck 2wd or 4x4?
    Default 2wd
    Thank you, and its a 2WD
    Gorg
    Quote Originally Posted by Gorganaut View Post
    Gorg
    There are Couple.....G.M. TSB.....Regarding......Clicking/Ticking and/or Piston Slap on the Silverado's,
    Here is one those G.M. TSB.....that may or may not apply to the noise you are hearing coming from your Silverado,
    File In Section: 06 - Engine/Propulsion System......Bulletin No.: 02-06-01-038
    Date: December, 2002
    Subject:......Engine Knock or Lifter Noise (Replace 0-Ring)
    Models:
    2001-2002 Chevrolet Camaro
    2001-2003 Chevrolet Corvette
    2001-2002 Pontiac Firebird
    2002-2003 Cadillac Escalade, Escalade EXT
    2000-2003 Chevrolet Suburban, Tahoe
    2001-2003 Chevrolet Silverado
    2002-2003 Chevrolet Avalanche
    2000-2003 GMC Yukon, Yukon XL
    2001-2003 GMC Sierra
    with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, Z, G, S, N, U - RPOs LR4, LM7, L59, LS1, LS6, LQ9, LQ4)
    Condition........Some customers may comment on an Engine Tick Noise. The distinguishing characteristic of this condition is that it likely will have been present since new, and is typically noticed within the first 161-322 km (100-200 mi). The noise may often be diagnosed as a collapsed lifter. Additionally, the noise may be present at cold start and appear to diminish and then return as the engine warms to operating temperature. This noise is different from other noises that may begin to occur at 3219-4828 km (2000-3000 mi).
    Cause......The 0-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
    Correction.......Inspect the 0-ring seal and replace as necessary. Use the applicable part number listed below. Refer to the Engine Mechanical sub-section of the appropriate Service Manual.
    thank you for the info, im gonna try checking that o-ring if switching to synthetic motor oil and adding some fuel injector cleaner doesnt work, I was informed both could possibly solve the problem. Just so happens im mechanicaly inclined so I am starting there and will try each solution i come across till I get it. Where can i find articles like the one you refrenced to?
    Gorg
  1. Clicking coming from the back of engine
    By ChevyGirl93 in forum General Chevy & GM Tech Questions
    Last: 09-02-2010, 10:27 PM
  2. Ticking/clicking Front tire/09 Silverado
    By normal_deviation in forum General Chevy & GM Tech Questions
    Last: 08-12-2010, 05:15 PM
  3. Constant clicking in engine bay
    By jeremiahweed28 in forum GM Powertrain
    Last: 08-04-2009, 11:20 PM
  4. 2002 Silverado p0443 engine code troubleshooting help please
    By kenwindsurf1 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 09-21-2008, 11:44 AM
  5. Clicking sound under 2000 silverado
    By mikey82 in forum GM Powertrain
    Last: 03-15-2008, 04:15 PM
