Thread: 76 K-frame
    Default 76 K-frame
    I have a 1976 SWB 4X4 and found that the frame is rusted and broken at the left front rear spring mount on the frame. What year frames will swap out or closely match the frame that I have? I may have located an '85 frame. The truck is too good to scrap and not so good that I am concerned with how it will look if I patch up the frame. Any ideas?
    With minor modifications every year from 1973 up to 1991. The frame didnt change a lot but some of the holes and brackets are in different places.
    Oct 2008
    Peoples Republic of Kalifornia
    I had a 1976 Blazer, and as I recall, frame problems were not uncommonon those models just like the problem with the hood bending from the strong springs that held it open. If it were me, I would check with JC Whitney to see if they still carry any of the older frame reinforcement products. Secondly, I would contact a local frame shop re: what it would cost to have it repaired. Good luck.
    1993 K-2500 Suburban Silverado, 7.4L, 4 X 4, HD Towing
    1985 Jeep Scrambler 4.2 L, 4 X 4, Laredo
    2005 Dodge Dakota, 4.7L, 4 x 4,, TRX4, SLT
    Two significant changes between the 80 down/81 up frames. The front horns and core support mounts are different. Will take some work to make it work. Also, the rear cab support crossmember sits lower on the 80 down. If you use the newer frame, you should be able to just use rear cab bushings for the new frame.
    I would look for a home shop welder/fabricator to patch your frame. They usually work for reasonable money, and will tell you right away if the frame is beyond repair.
    Also, the K10/15 and K20/25 frames are all the same, the K30/35 is different.
  1. diff in 2wd frame and 4x4 frame
    By 2wheelmudder in forum Lifted & Offroad Suspension
    Last Post: 05-19-2011, 01:32 AM
  2. Frame rust
    By ThePOPE490 in forum General Chevy & GM Tech Questions
    Last Post: 09-09-2010, 03:23 PM
  3. repainting frame
    By coombia21 in forum Chevy Truck Accessories
    Last Post: 09-20-2009, 02:01 PM
  4. Rust on frame???
    By 08bowtie in forum General Chevy & GM Tech Questions
    Last Post: 09-06-2009, 10:22 PM
  5. anyone have a rusty frame?
    By chevyman2004 in forum General Chevy & GM Tech Questions
    Last Post: 07-31-2009, 02:14 PM
