    Default 97 Silverado - Mysterious Short
    1997 1/2 ton Silverado 350 Ext Cab Auto
    This truck has a mysterious short, it began about two months ago. The short will drain the battery within 1-2 days. A local shop is having issues finding the short, they have checked the battery, there is no Engine light coming on, the alternator works fine, and there is no draw when it's first turned off.
    Oddly, and probably a coincidence, but the first time this happened was after another shop did some checking of the air bag system (the Airbag light was coming on).
    Are there any known (mysterious) electrical issues with this model year?
    Any suggestions will be appreciated.
    Tom Finlay
    Tom,
    The best way I know to find your short is by installing a volt meter or test light in series with the battery, if you have voltage or the light glows you have a draw on the battery, start removing fuses one at a time to isolate the circiut that is causing the draw, after you have identfied the circuit you will need to start disconnecting the componets on that circuit and observing the draw, if removing the componets from the circuit does not stop the draw it is most likely a wire shorting to ground, time to start looking for the shorted wire. A common place for shorts on older vehicles in in the flloor area where water can attack the harness and cause corrision.
    Good Luck
    Default Thanks!
    Quote Originally Posted by Bigg Ron View Post
    Tom,
    The best way I know to find your short is by installing a volt meter or test light in series with the battery, if you have voltage or the light glows you have a draw on the battery, start removing fuses one at a time to isolate the circuit that is causing the draw, after you have identfied the circuit you will need to start disconnecting the components on that circuit and observing the draw, if removing the components from the circuit does not stop the draw it is most likely a wire shorting to ground, time to start looking for the shorted wire. A common place for shorts on older vehicles in in the floor area where water can attack the harness and cause corrision.
    Good Luck
    Those all sound like good and easy-to-do tips, so I'll start there. Many thanks!
  1. Mysterious Coolant Leak
    By Cal_truck22 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-14-2011, 01:22 AM
  2. mysterious achievement....
    By clgoch187 in forum Announcements & Feedback
    Last: 12-05-2010, 07:47 AM
  3. Mysterious Oil Leak
    By Selbona in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-17-2009, 09:35 PM
  4. Mysterious Noise
    By Sawfish in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-28-2009, 11:29 AM
  5. Mysterious Rough Idle
    By tnvolsone in forum GM Powertrain
    Last: 09-27-2007, 01:24 PM
