    Default HELP!!!!Changed fuel pump and ECM. fuel pump still wont turn on
    I am working on my uncles 99 chevy 5.3 and he was told the ecm was bad so I changed that out and still nothing from the fuel pump. I had a known good fuel pump that I dropped in and still nothing? What else do I need to look at? I am a cummins diesel guy so not sure where else I need to start looking on this truck. Thanks for the help.
    stephan's Avatar
    Far West, Oregon USA,
    Welcome to the club Stang. About all that's left that you haven't done so far is the FP relay & the wiring loom. Look for the FP relay on the firewall a little left of center
    3" susp. lift kit "shadetree"
    Quote Originally Posted by stephan View Post
    I swapped out the relay as well. Could it be the PCM/fuse panel itself? Which wire is the power wire at the tank that I need to check for?
    stephan's Avatar
    Have you checked the relay to see if it's getting power to & out? I don't know the color for your truck cuz my diagram is not for that year, but it shows tan & white wire for the FP prime.
    Have a helper turn the key while you check for power into & out of the relay.
    Have you done a fuel pressure test? The two heavier wires at the pump should have 12V for about two seconds when you key on.
  1. Nylon Fuel Lines/Fuel pump recommendation
    By jed1124 in forum Chevy Truck Accessories
    Last: 03-21-2011, 08:10 PM
  2. Replies: 4
    Last: 09-19-2010, 06:16 PM
  3. Fuel pump delays to turn on
    By silverado00 in forum GM Powertrain
    Last: 08-03-2010, 12:31 AM
    Last: 09-26-2008, 05:10 PM
    Last: 09-05-2008, 02:55 PM
