    Default Tire Size question?
    I was looking at putting some wider tires on my stock 08 silverado, it has 275/55/20 and i was wondering if 305/50/20 would fit? or if any one knows if they are to wide. thanks.
    Welcome to GMTC,
    Please see sticky on the Suspension forum. There is a nice chart there.
    http://www.gmtruckclub.com/forum/sho...ft-Requirement
    2009 Silverado 1500
    5.3L / 3.73 G80 / 4spd / 4x4 / LWB/ Ext Cab / HD Tow-Haul
    2.25in ReadyLift Level Kit / 3in blocks/ 3500lb HellWig / 265x65x17 Wrangler AT
    K&N Filter / AirRaid MIT / MagnaFlow 2.25" Dual Exhaust / HyperTech MaxEnergy
    Welcome to the club.
    Do you know the backspacing on an 2008 silverado 1/2ton with factory 20inch 5 spoke wheels?
    Quote Originally Posted by kingaudis4 View Post
    If the below Rim is the one you are asking about??....Factory Alloy 20in" Rims have a....Backspace of 6ins" and a Offset of...+31mm
    Wheel Size: 20 x 8.5
    Bolt Pattern: 6 x 5.5
    Finish: Machined Silver
    Has this issue been resolved? I can also look into this for you. In order to do further research, I will need the VIN for the vehicle. Please feel free to contact me by private message as well. Thank you in advance.
    Tricia, GM Customer Service.
    Nov 2010
    McConnells, South Carolina
    I can fit 37's on a 2" body lift on my 1500 HD
    A Z71 with for keys can fit 35-12.50's with rubbing.
    But if you ain't rubbin you aint riddin!!!!
    But yes 305's will fit o stock rims. but when you start to get bigger rims and wider rims the rim itself begins to rub which in no bueno!
  1. Tire size question
    By silverado8 in forum Wheels & Tires
    Last: 01-02-2010, 02:29 PM
  2. Another Tire Size question.
    By Corins in forum Wheels & Tires
    Last: 12-29-2009, 07:31 PM
  3. Hey tire size question
    By rscottk90 in forum Member Introductions
    Last: 10-05-2009, 09:24 PM
  4. Tire size question
    By Petron in forum General Chevy & GM Tech Questions
    Last: 06-05-2009, 05:14 PM
  5. 06 HD tire size question
    By bluedog in forum Chevy Silverado Forum (GMC Sierra)
    Last: 11-06-2008, 11:20 PM
