    Default I have never added or changed fluid in my transfer case....
    ..so I now need to add some after leaking some out the back of it while changing the U-joints. What came out was pink in color. I expected gear lube in a transfer case but this looked like ATF.
    What fluid should be used?
    '95 Chevy Suburban 4x4 LS 5.7L
    Its is ATF. I use Mobil 1 synthetic ATF fluid.
    ---------- Post added at 04:06 PM ---------- Previous post was at 04:04 PM ----------
    The newer transfer cases use the AutoTrac ll fluid.
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    Thank you sir.
    Quote Originally Posted by silveradotrailblazer View Post
    Its is ATF. I use Mobil 1 synthetic ATF fluid.[COLOR="Silver"]
    What he said.
    At least you had some leak out. These cases are often neglected till they are dry.
    Quote Originally Posted by 2COR517 View Post
    I lucked out. I don't know if it was serviced before I bought it a 97k miles, but it now has 207k and this is the first time I looked at it.
    It is a 95 suburban, so I assume a standard GM ATF is indicated, unless I switch it to synthetic?
    I use the synthetic in the 'Burb because you do have a tendency to forget about the transfer case.
    :cool:
    Dash mat cover
    :glasses:
    If it lasted that long, it was probably synthetic. Conventional Dino ATF has a problem with "misting off". One of the reasons GM changed the fluid spec to synthetic.
  1. Transfer Case Fluid Leak
    By Huntr in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-09-2012, 02:10 PM
  2. Mercon VI transfer case fluid compared to GM Auto-Trac II fluid
    By Loyal Chevy fan in forum Maintenance & Upkeep
    Last Post: 04-13-2011, 06:02 PM
  3. Changing transfer case fluid
    By Silverado Junkie in forum Maintenance & Upkeep
    Last Post: 07-31-2010, 10:22 PM
  4. How do I change the fluid in my transfer case and diff?
    By blackrat in forum General Chevy & GM Tech Questions
    Last Post: 06-09-2010, 08:09 PM
  5. Transfer Case Fluid
    By ccmnova in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-19-2009, 07:24 PM
