Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Master Mechanic
    Aug 2010
    Gettysburg, Pennsylvania, United States
    be carefull with a used turbo...especially a cheap one.
    03 Silverado 1500
    285/75/16 BFG's
    2 Blaupunkt 10" vW1000 subs in Subthump box
    ProComp Level Lift & 3" rear blocks
  2. #12
    How would adding a supercharger help with fuel economy? I have never delt with one for cars, but I thought that with the increase in air to keep the ratio right you had to inject more fuel. With that being said that means more fuel being used. Right?
    Has anyone ever used or have any experience with the turbo kits that install at the rear of the vehicle instead of under the hood?
  3. #13
    Quote Originally Posted by aloxdaddy99 View Post
    Tuned correctly you can turn down the fuel/airflow rates a little with a supercharger, but the real key to gaining or maintaining mileage is by keeping the right foot in check.
    STS (Squires Turbo Systems) is probably the most popular rear turbo, over the years their product has improved quite a bit, but they still arent recommended for trucks operated off-road or in real damp areas incoming air is picked up at the rear of the truck under the bed which leaves them susceptible to sucking in to much water vapor, I havent seen them hydrolock unless you put the rear under water (which I have seen once) but they run real rough in high rain conditions.
    Building your own turbo system almost always cost's more than a prefab system built for a specific model and it takes a lot of tweaking to get everything working correctly.
    I have a homebuilt turbo system I run on my 91 rockcrawler Toyota that I have close to $7k invested in and over 5 years tweaking to get it to run right.
    My 99 Tacoma runs a Factory TRD Supercharger that worked flawlessly out of the box and cost about $3500 even with a few add-on options.
  4. #14
    Master Mechanic
    Aug 2010
    arent turbos most effective when they're mounted as close to possible to the exhaust ports? so why run it back so far? ive seen the under bed turbo set ups on trucks b4 but thats mostly cus they cheaped out and didnt wanna go twin turbo or fab a new exhaust system
  5. #15
    What size is the turbo Garrett is a good company for turbo's. Like alot of other people said you need to do alot of work to your truck before turboing it. Super chargeing it would be easier than turbo but I think it would be alot sicker if you turbo it . Feel free to ask me any question about turbos alot of my friends have WRX's and Audi S4 B5 along with turbo diesel truck's so I know a decent amount about turbos.
    *2010 Chevrolet 1500 LT
    *extended cab Long bed
    *Line-X bed liner
    *Rough Country 2 inch leveling kit
    *k&N Cai 63
    *Bullydog gt
    *custom A-pillar
    *17 Hoss XD
    *BF Goodrich Mud terrain KM2 285/70/17
  6. #16
    Hey man about how much would a single garret turbo cost with the complete kit?
    2008 Chevy Silverado Ext. Cab Lt Z71 5.3 V8
    7.5 Inch Rough Country Suspension Lift
    RBP Replica Grille Black w Chrome Rivets
    Recon Smoked Cab Roof Lights
    N-Fab Powdercoated Gloss black Cab Length Nerf Steps
    5% Tint over 20% all the way around / 5% Eyebrow Strip
    AVS Smoked Window Visors
    Z71 Stickers Black & Metallic Silver
    Tow Mirrors / Smoked Turn Signals
    XM Satellite Radio Fin / Color Matched
    Interior Plastic Pieces / Color Matched
    Power Acoustic Tweeters
    Painted Bowties / Color Matched
    Painted Door Handles / Color Matched
    Smittybilt Bull Bar / Color Matched
    Custom Rolled Edge Exhaust Tips / Color Matched
    Custom 2.5 Inch Cat Back True Dual Exhaust
    Flowmaster Super 40 Series Dual in / Dual out
    Magnaflow Tru-X Pipe
    K&N Air Filter
    18x9 Rockstars Machined Black
    Center Caps / Color Matched
    33.13.50 Nitto Terra Grapplers
    New Front Wheel Well Liners
    Eagle Eye Black L.E.D. Tailights
    Eagle Eye Black L.E.D. Third Brake Light / Smoked
    Eagle Eye Black L.E.D. Halo Projector Headlights
    Notto HID Kit 10,000k Low beams
    Recon L.E.D. Light Bar
    Buschwacker OE Style Tailgate Cap
    AMI Gloss Black Antenna
    Debadged Chrome Lettering
    Door Molding Removed
  7. #17
    if it were me id look into a trick's turbo think there stage 1 kits are 1800 and a innercooler is like 500 there good kits and rly good prices.... call em up
    2004 gmc sierra ext z71
    5.3
    PERFORMANCE...
    Air-aid cai : Longtube headers with cat delete : Ported throttle body : Flowmaster super 44 : Vette servos : TB coolant bypass : Nelson 91 Pcm : Tr 220 Cam : LS7 springs : Ls7 Lifters : Stage 3 heads : Custom Intake Manifold : TB Injectors : Plx gauges
    APPEARANCE...
    Custom Speedo : Leveling kit :Smoked taillights and 3rd break light : Black projectors and fogs with hids : Blacked out grille : 33's on 16's : Clarion Audio :
  8. #18
    well that isn't that bad really for a kit and a intercooler i prob could get cheaper off ebay or somethin so all in all $2,200 wouldnt be bad at all for the power gain even though i would rather have a supercharger but 5 grand is allot of cash to throw around for a performance part!
Similar Threads
  1. sirius universal tuner
    By Badbrad469 in forum Audio, Video & Gadget Tech
    Last Post: 12-25-2010, 06:58 PM
  2. universal performance chip??
    By rackchaser71 in forum GM Powertrain Tech
    Last Post: 04-22-2010, 01:14 PM
  3. Add Universal Home Link to 2009?
    By Padre in forum Audio, Video & Gadget Tech
    Last Post: 11-10-2009, 04:50 PM
  4. Are keyless remotes universal?
    By Tdaz250 in forum Audio, Video & Gadget Tech
    Last Post: 08-31-2009, 12:08 PM
  5. 1987 Universal Joint on 1/2 ton [Expired Topic]
    By Icewos in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-30-2006, 10:12 PM
