Results 11 to 14 of 14
    Forget taking it to the dealer or the reprogramming garbage. Pull the servo. It was under the cover below the passenger dash on my 2005 suburban. There are two of them. You want the one on the left closest to the hump. 5 screws and some alcohol later and my issue was resolved. Open the servo carefully. Take a pic of the gear position in case you drop it. Remove the main black gear only. Clean the contacts with rubbing alcohol and a q-tip. Remove any excess grease. They packed so much grease in the servo that the contacts become fouled. I cleaned mine and haven't had the Chevy lemon issue again. In fact, it blows ice cubes now. Chevy will sell you on all kinds of expensive parts and labor. Avoid the dealer at all cost and do it yourself.
    Quote Originally Posted by Bob marchiwitz View Post
    How much alcohol does it require? I'm planning on a six pack for this repair myself.
    Sr. Engineer
    Dec 2011
    11-22-boogie woogie avenue
    Gitter done. With rep.
    Tried the rest method, failed for my situation. I have a 2001 LT Burb. I was wondering if the servos are in the same locations? Do I need to worry about the pass airbag. I am no nub with a screwdriver, but I do not know how to correctly take off the cover. Thank you guys and I am itching to fix this problem.
  1. 07 tahoe heat blowing out of the driver side vent with ac on
    By adamant in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 09-15-2012, 05:29 AM
  2. 2004 Tahoe keeps blowing left turn fuse
    By coppcarz in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 12-13-2010, 08:05 AM
  3. chevy silverado dash vents dash part ac heat vents
    Last: 10-15-2009, 06:00 PM
  4. heater/vents not working, only blowing to floor
    By thattallguy32 in forum General Chevy & GM Tech Questions
    Last: 10-12-2009, 12:50 AM
  5. '90 Suburban a/c air vents & switch question..?
    By omnisi in forum General Chevy & GM Tech Questions
    Last: 05-17-2009, 05:07 PM
