Results 1 to 10 of 20
    Default Changing Diff Fluid....
    I am going to be changing the diff fluid on my Wifes 2006 Dodge Ram 1500....it takes 75w-140 synthetic....the truck has limited slip and the bottles of oil state "limited slip"...so do I still need to add the limited slip additive?
    Also is there a gasket or anything I need to replace while i am there usually?
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    I don't think you need the additive if it already says limited slip fluid. Also yes make sure you get the gasket!!!
    Also get a few cans of break parts cleaner cuz while you have that rear pan of go ahead and spray that stuff in there and it will clean out all the grime and old oil.
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    how often does anyone need to change diff fluid? I plan on changing mine sometime before next month.
    2008 Chevy Silverado Ext. Cab Lt Z71 5.3 V8
    7.5 Inch Rough Country Suspension Lift
    RBP Replica Grille Black w Chrome Rivets
    Recon Smoked Cab Roof Lights
    N-Fab Powdercoated Gloss black Cab Length Nerf Steps
    5% Tint over 20% all the way around / 5% Eyebrow Strip
    AVS Smoked Window Visors
    Z71 Stickers Black & Metallic Silver
    Tow Mirrors / Smoked Turn Signals
    XM Satellite Radio Fin / Color Matched
    Interior Plastic Pieces / Color Matched
    Power Acoustic Tweeters
    Painted Bowties / Color Matched
    Painted Door Handles / Color Matched
    Smittybilt Bull Bar / Color Matched
    Custom Rolled Edge Exhaust Tips / Color Matched
    Custom 2.5 Inch Cat Back True Dual Exhaust
    Flowmaster Super 40 Series Dual in / Dual out
    Magnaflow Tru-X Pipe
    K&N Air Filter
    18x9 Rockstars Machined Black
    Center Caps / Color Matched
    33.13.50 Nitto Terra Grapplers
    New Front Wheel Well Liners
    Eagle Eye Black L.E.D. Tailights
    Eagle Eye Black L.E.D. Third Brake Light / Smoked
    Eagle Eye Black L.E.D. Halo Projector Headlights
    Notto HID Kit 10,000k Low beams
    Recon L.E.D. Light Bar
    Buschwacker OE Style Tailgate Cap
    AMI Gloss Black Antenna
    Debadged Chrome Lettering
    Door Molding Removed
    Quote Originally Posted by Rockstarrchevy81 View Post
    My Haynes manual says every 60,000 miles or 48 months, thats for the 1999-2006 models. It's probably the similar if not the same for the NNBS trucks.
    oh okay ha well that puts me at perfect timing then thanks man.
    K&N Air Filter
    Stoner what brand of gear oil are you going to use? Just interested in what other people use and if they have any particular reason for using that brand. I have heard a lot of good things about Amsoil products. I started using it in my Harley and do notice a little difference in hoe the motor runs.
    Jr. Engineer racekid91's Avatar
    Feb 2011
    Green Bay, Wisconsin, United States
    Just did mine two weeks ago. I pulled the cover, cleaned everything up with brake cleaner. New gasket. Used a friction additive for my G80. Also did my front differential. Just a drain and fill.
    1995 Chevy Tahoe
    I got valvoline synthetic....i looked at lucas and some others but they didn't have the weight I needed.
    Get the Gorilla!
    gorilladip.com
    I plan on changing my diff fluid and gasket. Which kind of diff fluid and weight along with which kind of gasket. Also can i pick this up at autozone etc. ?
    K&N Air Filter
    You can probably find what you need at Autozone, Pep Boys etc.... I'm sure they'll have it.
  1. Changing power steering fluid
    By ridick_bowen in forum Maintenance & Upkeep
    Last Post: 05-18-2011, 12:32 PM
  2. changing brake fluid on 04 tahoe
    By mike042 in forum Lifted & Offroad Suspension
    Last Post: 04-05-2011, 11:36 AM
  3. Changing transfer case fluid
    By Silverado Junkie in forum Maintenance & Upkeep
    Last Post: 07-31-2010, 10:22 PM
  4. changing tranny fluid
    By IThurstSObad in forum Chevy C/K Truck Forum
    Last Post: 12-26-2009, 12:35 AM
  5. Thinking Of Changing Your Tranny Fluid Yourself???
    By 1st Synthetics in forum 1st Synthetics
    Last Post: 03-04-2009, 09:24 PM
