Results 1 to 10 of 11
    Default Driver door speaker
    My driver's side door speaker has crapped out on me... sounds busted, even though I don't listen to music loudly. Where can I get a good (but cheap) replacement and are they hard to get to?
    Matt
    Wichita Falls, TX
    2007 Chevy Silverado 1500 Classic LS 4x4, 4.8L
    Thrush Welded muffler, dual exhaust
    HELO MAXX6 18" Rims, Torza Tri Fold tonneau cover :glasses:
    Quote Originally Posted by mvoss2576 View Post
    You will need to remove the door panel to get to the speakers.....Below is a link with step by step Instruction's.....on remove the door panel.....as far as speakers....take a look at CrutchField.....they carry just about every speaker made today.....and the speaker size is....6-1/2in,
    Link,
    http://www.bodyshopzone.com/archives...move_brbn.html
    murdog94's Avatar
    and anything other than stock will be more than sufficent since the factory GM speakers are junk in the non bose/monsoon models.
    Im personally going to best buy to replace mine... CHEAP!!!
    Mike
    Currently
    2011 F-150 Crew 4X4
    Quote Originally Posted by murdog94 View Post
    X2, anything is better than stock. How much are you willing to spend for new speakers? I got a pair of Rockford Fosgate's for $60 shipped and for the amount I paid, they're great.
    Yeah speakers can be very cheap. Like everyone else said go ahead and buy one for each door and I think you'll be pleased with whatever you end up with.
    2006 Duramax LBZ
    Edge Evo
    4'' Diamond eye to 6'' tip
    Lots of work left to do!
    They are cheap, I'm running mine tell they blow then I will buy new ones .. LOL ... right rear has since produce no sound at all .. one more then I will get them replaced !! I would replace all your factory speakers, sooner or later the rest are going to go south on ya.
    long time rockford fosgate guy !! (thats what I would replace them with imo)
    Jr. Mechanic Bowtied's Avatar
    May 2009
    2004 Silverado 5.3L
    Hi guys im in a similar situation, i need to test my speakers and i know for sure the left front speaker is turning on and off im not sure if this is a blown speaker or Blown speaker + disconnected wire issue. is there a way to test connectivity without removing the door panels?
    Well there is a way but it involves tracking wires in the cab and you'll probably have to end up removing some type of molding. The door panels really aren't that hard to remove and I would say is your best bet at solving your problem.
    2006 Duramax LBZ
    Edge Evo
    mvoss, the same thing happened to me on my '08: driver's side door speaker went kaput. I don't less to music extremely loud either. I noticed one day the headlight warning chime was very faint, then I started playing around with the balance and fader. The speaker was operating intermittently. Luckily it was still under warranty, so I let the dealership take care of it. I don't expect much from factory speakers, but damn, you are the third person I've heard that had the same problem.
    -Sal
    Desert Brown Metallic
    Quote Originally Posted by drwombat View Post
    Get a rubber mallet and bang around the door, see if anything gets better LOL ... anyways yea, best bet would be take off the door panel. GMT800s are a little easier (imo) GMT900 is a bit more of a job, more bolts to deal with. You could also test when vehicle is parked, see if it sound alrite if it is going in out with decent quality then probably loose connection somewhere, or just tune into that speaker and drive around, hit a couple pot holes and it comes in and out (without a bunch of crackling, popping hissing) then its probably a loose wire.
    If I have to take my door panels to troubleshoot speakers I would just buy new ones (unless you already have aftermarket) --- i hate dealing with door panels
  1. Rear Door Speaker No Sound
    By FergusonT in forum Audio, Video & Gadget Tech
    Last Post: 08-12-2010, 09:48 PM
  2. door speaker wire's
    By MBurke in forum Audio, Video & Gadget Tech
    Last Post: 03-23-2010, 12:02 PM
  3. Weird Door Speaker Problem
    By rmallory in forum Audio, Video & Gadget Tech
    Last Post: 05-17-2009, 04:03 AM
  4. Door speaker question
    By Hunter2926 in forum Audio, Video & Gadget Tech
    Last Post: 04-19-2009, 11:30 PM
  5. 07 silverado door speaker size
    By coachg08 in forum Audio, Video & Gadget Tech
    Last Post: 02-26-2009, 09:36 AM
