GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: oil leak
  1. #11
    Sounds to me like it could be leakng from the intake manifold, those neoprene gaskets are know to leak espically in the corners. I dont even use them, I use RTV and leave them out. Or possibly the valve cover gaskets, I just repaired my oil leak which was comming from the VC gaskets, thought I had a main seal leaking until I removed the cover and it was dry in there.
    From working in dealers for many years, i will say that they are hitting all the right spots, although they probably would have been farther ahead now if they would have pulled your engine and did a total reseal.
    Good Luck at the new dealer.
  2. #12
    Sr. Apprentice
    Nov 2008
    Coventry RI
    just got off the phone with the new dealer thet can't touch it because the other dealer has been working on it so it their problem
  3. #13
    Sr. Apprentice
    Nov 2008
    Coventry RI
    two more times at the dealer new oil pan gasket, second new oil pan and new gasket and still leaking I don't know what more to do
    No other dealer will touch it because of all the repairs even when it's under warranty
  4. #14
    Legend
    Caddiac's Avatar
    May 2011
    Upstate South Carolina
    This sounds like a job for the Ask GM Customer Service here on the site.
    We have another guy from Coventry RI on this site. He ought to come over to your house and fix it for ya! I hear he is a genius.
  5. #15
    Sr. Apprentice
    Nov 2008
    Coventry RI
    I 'am working with GM customer service already so far no fix and if you know the other guy from Coventry look him up please
  6. #16
    Legend
    stephan's Avatar
    Sep 2010
    Far West, Oregon USA,
    Quote Originally Posted by Bigg Ron View Post
    I gotta go with Bigg Ron on this one. The rear of the intake manifold leaks whether you use gaskets or silicone sealer on them. Then it runs down between the engine block & the trans bellhousing making it appear like it's the rear crank seal or the rear pan gasket/seal. That's about all that's left that they haven't tried to repair yet.
    Serg, why don't you reach down behind the intake manifold & firewall, touch the joint between the mani & the engine block & see if it's wet. If it is, this is about the only thing that is that high that could be leaking.
    1988 Chevy C-3500 2wd (no pic)
    350 c.i. 5.7 L Stock Block, 4 Bolt Mains
    L-31 Vortec Heads, Edelbrock Cam & Intake,
    Holley 650, Flowtech Headers, Magnaflow exh.
    Jet Trans 700R4, B&M Ratchet, 4:10 gears,
    3" susp. lift kit "shadetree"
    No rev limiter, No speed limiter lol
  7. #17
    Sr. Apprentice
    Nov 2008
    Coventry RI
    I will try that as soon as I get home tonite thanks guys
  8. #18
    Hi sorry im 3 months behind, but My suburban is doing the same thing as your car. Did you ever check around the back of the Intake manifold and find a leak there?
    2001 Suburban 2500 4x4: Kid hauler
    6.0L V8
    4.10 G80 rear end
    All stock so far....
    1992 Honda Civic HB: My fun toy
    track car (sometimes DD.....sometimes)
    Best E/T: 11.1 @120mph
Similar Threads
  1. gm leak tabs on 5.7 intake manifold leak
    By raceville in forum General Chevy & GM Tech Questions
    Last: 01-13-2011, 02:06 PM
  2. Oil leak
    By mattpresley in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-29-2009, 04:11 PM
  3. what leak is this??
    By 9191gmc in forum Chevy Silverado Forum (GMC Sierra)
    Last: 07-05-2009, 08:07 PM
  4. Oil Leak
    By Black LT3 in forum Chevy Truck Tech Forum
    Last: 04-14-2008, 08:27 PM
  5. Oil Leak
    By makthenif in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 10-30-2007, 06:15 AM
