Results 1 to 2 of 2
    Default Temp Actuator - Climate Control: Driver side blowing hot when A/C is on, rewire?
    Newbie here and been reading alot of good stuff on here.
    I know this is a known issue, where either left or right temp actuator goes out.
    I found a few threads on resetting it, usually only when you replaced the actuator so that it can get reset.
    My question is this. can you rewire the left side to the right actuator so that you are bypassing the left alltogether and now both sides are controlled by the right (working one).?
    That way you can still control the temp with the right control and not having to buy a replacement left actuator?
    I just got the truck and I usually have a budget in mind with extra cash set aside for repairs. I came across this one where I needed to drain my maintenance fund to get it just because i liked it so much. So trying to do workarounds wherever I can if i can.
    Any thoughts, helps is appreciated.
    this is for a 2004 Silverado LS 2wd.
    thanks,
    -D
    Just wanted to bump this up just in case someone may have some ideas.
    -D
    2004 Silverado LS 2wd - std cab - long bed
    2006 Lexus IS 250 AWD
  1. 2004 Suburban AC starts Blowing hot air out driver vents
    By jes1766 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-07-2013, 09:58 PM
  2. 07 tahoe heat blowing out of the driver side vent with ac on
    By adamant in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-15-2012, 05:29 AM
  3. climate control
    By jdiggs in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-30-2010, 04:27 PM
  4. Need new Climate control
    By twarner776 in forum General Chevy & GM Tech Questions
    Last Post: 02-10-2009, 08:58 AM
  5. blowing only hot air from drivers side
    By mickey in forum General Chevy & GM Tech Questions
    Last Post: 07-28-2008, 12:15 AM
