    Default 95 chevy 350 oil loss
    i have a 95 chevy 350 with almost 200k miles. i have been losing a lot of oil and its not leaking from anywhere that i can see. suggestions? i had intake gasket problems but got that fixed and im still losing oil. its in spurts sometimes its a quart a day or a quart a week
    Hey RedneckGirl, long time no see. Check the oil sending unit when they go you will loose oil. Also do you see and smoke out the exhaust? Has this just started?
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    i havent noticed smoke but everything under the truck past where the exhaust is broke is black
    murdog94's Avatar
    Sounds like your valve seats are doing the typical chevy thing and going bad. if you start it when it is cold does it shoot out a puff of blue smoke.. and what brand and grade of oil are you running?
    Mike
    Currently
    2011 F-150 Crew 4X4
    no smoke when i start it in the mornings. it has a lot of black carbon coming out of the exhaust but my cat has come apart on the inside so i figured thats where its coming from. everything under the truck is black past the exhaust.
    Oct 2008
    Peoples Republic of Kalifornia
    You did not say whether it is 2WD or 4WD. If it is a 4WD, some models have an aluminum adapter that bolts to the block, which changes the mounting angle of the oil filter to allow clearance for the front drive shaft. There is an o ring type gasket between the block and adapter that is prone to leakage. This has been the source of the "mystery oil leak" on a number of Chevy 4WD trucks I have seen. If that is not the source, it could be a leaking rear main seal.
    1993 K-2500 Suburban Silverado, 7.4L, 4 X 4, HD Towing
    1985 Jeep Scrambler 4.2 L, 4 X 4, Laredo
    2005 Dodge Dakota, 4.7L, 4 x 4,, TRX4, SLT
    Very good Sawfish, I forgot about those filter/block adapters.
    It is 4wd. If it was leaking that much out of an o ring though wouldn't I notice spots under the truck? I look everytime I park and there is never any oil spots. The rear main does leak but not enough to where it leaves spots just enough where u notice it when you get under the truck to change the oil.
    Amber- Indiana
    1995 Chevy 1500 4X4
    stephan's Avatar
    Far West, Oregon USA,
    Quote Originally Posted by RedneckGirl View Post
    Definitely! One quart of oil would make a slick 4 feet in diameter on your floor. Don't ask me how I know this
    Your engine must be burning it. It could be pulling it through the valve stem seals into the combustion chambers, (valve stem seals went bad on mine at 100K miles & they've been known to fail at fewer miles than that) or it's getting past the rings into the combustion chambers & burning it. You could pull a few spark plugs to verify.
    3" susp. lift kit "shadetree"
    thanks i will do that
  1. 1997 chevy C/K 5.7L loss of power at highway speeds
    By bosox91379 in forum General Chevy & GM Tech Questions
    Last: 01-29-2011, 06:33 PM
  2. 99 Chevy MPG loss
    By 7 point in forum Performance & Fuel
    Last: 12-23-2010, 07:11 AM
  3. Loss in power . No CEL
    By Danow in forum General Chevy & GM Tech Questions
    Last: 07-12-2010, 11:07 AM
  4. 89 Burb...sudden loss of fuel pump and loss of check engine light
    Last: 03-05-2010, 07:21 PM
  5. Coolant loss-BAD CAP.
    By phoebeisis in forum GM Powertrain
    Last: 04-18-2009, 03:21 PM
