Results 1 to 9 of 9
    Default '91 GMC Air conditioning problems.
    My air has always worked well but the compressor always made what i call a groaning noise when it operated and I could hear this inside the truck. I have owned this truck since it was a year old. Once in a while the AC would flash on the heater control and I would disconnect the battery and reset and it would work again. Now the AC doesn't work at all and the AC flashes every time I start it up. Is this more than a recharge problem?...is it worthwhile to try to fix?...thx
    stephan's Avatar
    Far West, Oregon USA,
    If it's lost enough freon that it won't engage the pressure switch then the compressor won't run at all.
    I wouldn't fault the compressor just yet, as mine has growled & knocked for 9 or 10 years. You can do a quick bridge of the pressure swtch (should be on the rec drier by the firewall) & if your ac clutch kicks in, then it's just low on freon.
    3" susp. lift kit "shadetree"
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    If the A/C is blinking, that is a signal that the pressure is not right.
    So adding in more Freeon should correct that problem, once enough is in there, it can get its pressure right.
    I have had some loud noises from the compressor on mine....to the point I thought it would blow up and shoot through the hood of my truck....
    I went and added in some more Oil last night, and I think I have corrected the issue....
    I need to take it out for a drive and test it, but I hope I have corrected the problem.
    Quote Originally Posted by MightyMax View Post
    How do you add oil to the AC system?
    Sr. Engineer
    Aug 2009
    Virginia Beach, VA.
    You will need a set of guages, and then go down and buy some pressurized oil at Adv. Auto or something, and add it in like you would R134
    tried to bridge the low pressure switch, but no go...the compressor will not fire over...now what?
    You have to reset the control head by unplugging it or disconnecting the battery cable first, then you can jumper the connector to see if it will work.
    Good Luck and God Bless
    I noticed that the high pressure schrader valve was hissing slightly..fixed that, disconnected battery, jumped the low pressure, reconnected battery, started vehicle and set air to high and dumped a couple cans of super secret R-12 and I'm cold....thx everyone
    Information on 91-92 gm c/k trucks gm bullitin (92-201-1b) problems with false clutch cycling would set of the a/c flashing light. GM would have you remove the a/c control had and disconnect the dk green circuit wire. this disables the low charge detection system. This only applied to 91-92 c/k trucks. tks, DanO
    2004 Duramax k2500 hd
    1996 K1500 350 Vortec
    2002 Harley Fatboy
    2002 Polaris 159 RMK
    1972 Nova w/502 6.5 @ 110 mph in 1/8
    1965 Chevelle 454 6.5 @ 108 mph in 1/8
    1997 Bonneville SSEI + too many more to list.
  1. Air conditioning won't blow.
    By cfoster in forum General Chevy & GM Tech Questions
    Last: 06-20-2011, 05:55 PM
  2. Air Conditioning Help!
    By kawierider1990 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 06-15-2011, 05:39 PM
  3. Air Conditioning noises and problems
    By Ronw435 in forum North America - Southwest USA
    Last: 04-23-2010, 01:55 PM
  4. Air Conditioning Help
    By dan.hendrickson in forum General Chevy & GM Tech Questions
    Last: 05-01-2009, 04:32 AM
  5. Air Conditioning
    By blueZ71 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-02-2009, 10:03 PM
