    Default Need new shocks!
    How do i measure what length i need?
    i have a 2" leveling kit and a 3" fabtech spindle lift
    i only need the front shocks
    csn anyone tell me how i determine the length of the shock i need? theres just so many options. or just point me in the right direction...
    and from what i hear bilstein is an awesome pick
    thanks for your help as always
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    The 3" spindle doesn't affect shock length. You need a shock that is 2" longer than stock. Bilstein has a longer shock for a leveled truck. I assume this is for your 2000 Silverado.
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    x2. Bilsteins are great shocks. if you look on their website they list the ones for lifted trucks. it will give you the lift range and tell you the shock you need. Also to check for length measure the distance from the top mount to the bottom mount. the lengths of the shocks are listed on the site (will give extended and collapsed). you would then want the distance to be in between the the collapsed and extended range. For example the 5100 series for your year with 6" front lift the shock is 11.3" collapsed and 17.58" extended. so if the measurement on your truck was 14-15" (closer to the 14)range this would work.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
    would you agree that the 5100 series adjustable shock is the shock that would suit my truck???
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Simply put yes.
    The 5100's are great shocks, they also have the 5125's that are universal and are sold based on length travel etc. My truck has the 5100's (made for lifted applications) up front and then I did the 5125's (universals ordered by length) in the back because I went with the longest one they had because of the rear lift height I had. for your truck they also had their regular shocks (the blue and yellow) in a comfort and HD model. those are made mainly for non lifted but you can always check the length. the comforts will give you that softer ride where as the hd's are going to be stiffer for more of the hauling etc. the 5100's seem to be a firmer (obviously adjust based on terrain) as well but I like the firm ride. so it depends on your likes. Either way I dont think I have heard any complaints on the bilsteins. most people rave about the difference in the handling. I definately recommend the bilsteins one way or the other.
    David
    NRA Life Member
    yeah im fine with a firm ride so long as the shock does its job and from what i saw the 5100 adjustable series adjusts from 0-2.5" for a leveled truck and seeing that silveradotrailblazer says that doesnt affect shock length i think thats the shock ill go for
    as long as someone can tell me thats the one or no its wrong i will be a happy camper
    thanks for your help guys
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    you just gotta find the right part number, but the bilsteins are the way to go.
    David
    NRA Life Member
  1. Shocks?
    By jmckee6 in forum Lifted & Offroad Suspension
    Last Post: 05-26-2011, 07:43 PM
  2. WTB-oem shocks for 08 Z71
    By dbs1 in forum General Classifieds
    Last Post: 02-06-2011, 02:05 AM
  3. Need shocks?
    By BurtsBurb in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-05-2010, 07:24 PM
  4. New shocks
    By buster024 in forum Member Introductions
    Last Post: 06-11-2009, 09:18 PM
  5. shocks
    By jaydub in forum Lifted & Offroad Suspension
    Last Post: 11-09-2008, 10:51 PM
