Results 1 to 2 of 2
    Default play in NV246 output
    I was just under the Suburban checking the drivetrain and I'm getting some up and down play in the transfer case rear output. With the wiggle is a "clink" coming from inside the transfer case.
    To start: how much (if any) play is allowed in the rear output bearing?
    Can the bearing be replaced without rebuilding the entire transfer case?
    Decided to get a 2nd opinion. The shop I took it to agreed that the output is getting loose. They said there is a bushing on these that is usually what wears out. They want quite a bit to change it, because they need to split the case to get to it.
  1. NV246 Shifter Shaft Knowledge?
    By Highside in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-11-2011, 02:42 PM
  2. audio output ?
    By irbya in forum Audio & Video Classifieds
    Last Post: 08-28-2010, 06:15 PM
  3. Head Unit Output?
    By MWright936 in forum Audio, Video & Gadget Tech
    Last Post: 05-22-2009, 09:11 AM
  4. Output shaft seal
    By thejms in forum GM Powertrain
    Last Post: 05-09-2009, 02:05 PM
  5. NV246 fluid recommendation [Expired Topic]
    By MrShorty in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-28-2006, 07:35 PM
