Results 11 to 12 of 12
    I'm going to buy a 1999 4x4 1500 Suburban today. I've done a lot of research on them, and it seems like much of the common stuff to look for has been listed above. The door handles break, the head gasket issues (the one I'm getting had it done not too long ago), the A/c going bad, and a few other little things. But, I have to say... there are a LOT of these vehicles still on the road with 200k-300k miles! They must not be all that bad!
    The one I'm getting supposedly has a small oil leak somewhere. I'm going to check it out closer. Not sure if they even know where the oil's going... hopefully it isn't something major.
    I like you.
    Jun 2006
    My 1998 2wd has 216,500 miles- thelast 4 years and 21000 miles are mine.
    They are reliable vehicles- but relatively cheap to fix- if you DIY- PARTS ARE READILY AVAILABLE- not too hard to work on.
    "Good" oil leaks are the timing chain cover and the oil pan-not too expensive not too hard to do-the intake manifold gaskets can leak oil also I think
    Rear main seal is more expensive and more work to fix.
    They frequently will continue to run leaksand all if you just replace fluids(not a great idea, but sometimes you have to-short of $$ or time)
    Heck I ram mine for a year with a leaky radiator-and for several weeks with a bad brake booster(had to be careful with that!!)
    They are sturdy-you can do a lot worse when buying a cheap <$3500 old high mile vehicle- it would be tough to find a more reliable-versatile- vehicles in the cheapo range-high gas prices means they are cheap to buy now.
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
  1. 2007 Suburban - Info from DIC about fuel + AFM?
    By jmichael in forum Performance & Fuel
    Last Post: 04-19-2011, 02:14 PM
  2. help with suburban tire info
    By aussie suburban owner in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-20-2010, 07:32 AM
  3. Suburban rear end info. help
    By iceman1936 in forum Lifted & Offroad Suspension
    Last Post: 12-05-2009, 02:23 PM
  4. anyone with info - lowering a '93 2wd Suburban
    By nitrozamboni in forum Lifted & Offroad Suspension
    Last Post: 10-12-2009, 09:30 AM
  5. Need info on 99 Suburban [Expired Topic]
    By vaughn in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-24-2006, 09:41 AM
