    Aug 2007
    Blackfoot, Idaho
    Default '98 5.7L upper coolant drain
    With much fighting, I managed to get the radiator drain valve open & drained the radiator. Went ahead & did two flushes (one with flush chemical, one with just water), and now I want to more fully drain the system before putting the fresh coolant/water combo in. Where is the upper coolant system plug located (assuming there is one...)?
    (I'll be getting a Haynes/Chiltons manual next week, but I'm hoping someone can help me out sooner than that...)
    1998 Chevrolet K1500 Suburban LS 5.7L(people hauler, mountain fun machine)
    1999 Saturn SC2 (project car)
    1999 Saturn SC1 (daily driver)
    Aug 2007
    Blackfoot, Idaho
    Upon further research, apparently it's a block drain, but I still don't know where it is...
    There are plugs on the block to drain it, but be careful removing them, sometimes they are rusted in and will break off. You can remove the quick-connect on the passenger side of the intake and force water down that, but be careful removing the quick connect because it can break too and will be a PITA to replace. It might be just as easy and safe to remove the upper and lower radiator hoses and run a hose down the upper and let if flow out the lower for a while. Just a suggestion.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    Aug 2007
    Blackfoot, Idaho
    Quote Originally Posted by GaryL View Post
    If I use this method, can anyone give me an approximation of how much water will be in the block, so I can account for that when I add coolant and get the right overall mixture?
  1. upper control arms
    By Burden33 in forum Lifted & Offroad Suspension
    Last Post: 05-10-2010, 12:16 PM
  2. drain coolant
    By j_weezy in forum General Chevy & GM Tech Questions
    Last Post: 11-07-2009, 08:12 PM
  3. low coolant light comes on and the coolant level is good...
    By kukini808 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-14-2009, 07:31 AM
  4. Replies: 5
    Last Post: 12-28-2008, 01:45 PM
  5. coolant drain plug [Expired Topic]
    By ziggy919 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-15-2006, 05:25 PM
