Results 1 to 10 of 12
    Default 2004 silverado-hot air blows out of driver side vents.
    2004 silverado - hot air blows out of driver side vents, pass side stays cold. Restart the truck, it returns to normal.
    stephan's Avatar
    Far West, Oregon USA,
    It sounds like the air door actuator is bad for that side Rod. Sometimes they strip out & reclycling the key or disconnecting the battery repositions them, but it doesn't last long before they're off again & can't move the air door or keep it tightly closed, so you end up getting heated air instead of AC.
    3" susp. lift kit "shadetree"
    I've had the exact same issue with my 04 Suburban Z71. I've even learned to turn the car off on the freeway to reset the actuator; when I turn it back on, the a/c works fine. I can't find a photo of the actuator and I don't know what it looks like or I'd try cleaning it or replacing it. If you find it, please post a photo! -Bill
    Default hot air coming from driveers side vents only
    I too have the same problem. Seems to do it randomly.. whenever it wants. It's almost like it seems to do it more often during the hot summer months.. compared to like during the Spring and early Fall seasons.
    I've got a 2005 Chevrolet Silverado LS crew cab.. just rolled over to 100k 3 days ago. But its been doing it for a while.. and I should have made time to take it to the dealership while the warranty was still in effect.. but when I bought the truck, I got the extended 100k drivetrain warranty.. but once again, she rolled over to 100k about 3 days ago.. so now I'm screwed and will have to pay for the repair.
    Anyone know about what this costs to have fixed? Just a ballpark figure...?
    This has happened in my '08 Silverado my Dad's '09 Silverado my Mom's '08 Tahoe and a lady I work with, her '05 Equinox. I think it is just something funky with GM.
    stephan's Avatar
    Did a google search for a pic & it lead me right back to GMTC (go figure, the best site on the net). Heres a link to a page where Steve is posting a blend door actuator for sale & it has a pic.
    http://www.gmtruckclub.com/forum/sho...Motor-Actuator
    Default $390
    I had this exact same problem on my last truck, a 2004 Silverado LT ext cab. Cost me $390 at an independent shop (parts and labor).
    i had the same problem on my 04 silverado. I work at an independent shop and all i paid was our price on the driver blend door motor which was $136. thankfully this is the motor that is accessable from the passenhger side by just removing the lower heater case cover. If it would of been any of the other motors it would require full dash removal, draining the A/C, cooling system....a whole lot of bull **** for a simple motor. very simple to replace
    I have an 04 silverado, with manual AC/Dual climate control>> been having this problem for about a year on and off...finally today i decided to investigate>>Took the left side temp actuator off was going to replace but instead there is like 4 clips that hold the housing together on the sides i used a small screw driver to open the clips and split the case... was careful to look at how it came apart.. but i took the white gear out which allows u to pull the black gear out notice where the tab is on the black gear, mark it with a marker if u have to.. underneath the black gear there are two metal tabs that looked to me to be the conductors that run on a halfmoon shaped electrical panel... Im assuming that this tells the computer where the door is located.. the clear grease that is on the gears had dropped onto the panel and coated the little conductors>> I bent the little tabs a little further so they had more pressure on the panel and cleaned the grease off of both reassembled the case and reinstalled it back into its position hooked the wire harness back up> And so far so good drivers side i can now control and it does not switch and blow hot air anymore>>> knock on wood
  1. 2004 Suburban AC starts Blowing hot air out driver vents
    By jes1766 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-07-2013, 09:58 PM
  2. 07 08 09 chevrolet silverado tail light driver side oem
    Last Post: 06-14-2011, 04:00 PM
  3. wtb: driver side shock for chevy silverado 2004 4x4
    By julio9817 in forum General Classifieds
    Last Post: 10-15-2010, 01:28 PM
  4. WTB 2005 silverado driver side mirror only
    By bacol14 in forum General Classifieds
    Last Post: 09-07-2010, 01:58 PM
  5. 2004 Silverado AC only blows on high
    By TELORVEHC in forum GM Electrical Tech
    Last Post: 05-05-2010, 08:37 AM
