Results 1 to 2 of 2
    Newbie
    May 2009
    Steenbergen, Noord-Brabant, Netherlands, Netherlands
    Default Valve cover bolt torque for my 454 V8 Chevy Suburban build 1979
    Can anybody tell me what the valve cover bolts has for torque?
    The books say 3 ft.nm but I have a torque key with Nm and Ft-Lb?
    Many thanks and God Bless
    stephan's Avatar
    Far West, Oregon USA,
    Hey Ton, my book shows 50 inch pounds of torque for the 454 valve cover bolts, so that would be 4.166 foot pounds on your wrench.
    In case you need them & can't find them here are some other torque specs for your 454
    Cylinder head bolts... 80 ft lbs
    Intake manifold........ 30 ft lbs
    Exhaust manifolds..... 20 ft lbs
    Rocker arm studs ..... 50 ft lbs
    Main bearing caps....110 ft lbs
    Connecting rods....... 50 ft lbs
    Flywheel bolts.......... 65 ft lbs
    Harmonic balancer.... 85 ft lbs
    Spark plugs............. 15 ft lbs
    3" susp. lift kit "shadetree"
  1. 99-01 Chevy Silverado Door Panel Mirror Bolt Cover OEM
    Last: 03-13-2010, 12:00 AM
  2. Leaky Valve Cover
    By Silverado Junkie in forum General Chevy & GM Tech Questions
    Last: 02-12-2010, 08:45 AM
  3. valve cover gaskets
    By sheep in forum General Chevy & GM Tech Questions
    Last: 03-08-2009, 01:16 PM
  4. body bolt torque specs
    By 1martian in forum Chevy Silverado Forum (GMC Sierra)
    Last: 02-05-2009, 07:25 PM
  5. Valve Cover Gasket Job
    By makthenif in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-30-2007, 11:09 AM
