Results 1 to 10 of 11
    Jr. Mechanic coldsteel1993's Avatar
    Apr 2007
    Niles, Michigan, United States
    Angry looking for a fuse box diagram
    I have a 86 Chevy Suburban. It has a 5.7 in it. The power windows all stopped working and I can't seem to find a spot in the fuse box that says Power Windows or something of that nature. Help Please.
    96 Chevy Suburban with a 350. Pretty much stock for now. Mods to come.
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Default Check AutoZone
    I found this diagram at AutoZone but it doesn't show a power window circuit. Could it be the one labled "pwr" ?
    High Desert SoCal
    02 Honda Civic LX
    If I remember correctly, in my 91 sub, the power windows and locks should be on either the "horn/DM" or "TL/CTSY" fuse. I blow one of those all the time, I can just never remember which. When I get home, I'll check my manual to give you a definite answer. If I remember correctly, the "PWR" fuse is basically the main for the block.
    Christopher
    Sep 2006
    Not to quibble, but power window motors draw high current. I would think that only a circuit breaker of 30amps would do the job. My 93 uses a 30amp cb.
    High Desert SoCal
    02 Honda Civic LX
    Not that a Suburban is anything like a Toyota Tacoma but I'd recommend pulling all the fuses and checking them one at a time it wont take but a few minutes with a fuse puller.
    On one of my Tacoma's I lost windows, gauges, A/C fan, and radio, right after hooking my trailer to the truck and putting it in reverse, a dealer tech told me to check the inst/gauge fuse, sure enough it was blown. Wanting to know why a trailer would blow all those items I started looking at the schematic and found those items all had a feed through the the gauges, only a relay wire, but when the fuse blew they stopped operating. Btw the trailer lights were still operating correctly.
    I got curious and looked at the system on my Suburban (1997) and found it had similar feeds to signal certain items. So now when I blow a fuse or have a electrical malfunction I make it a habit to check all the fuses.
    Apr 2007
    Thumbs up Thanks everyone
    It ended up being a ground. I did everything you guys said. But thanks for all the help. I am really amazed at how fast the replies were.
    Sep 2006
    Default Tell us more.
    How did you isolate the trouble to a grounding issue? Where was the ground fault at? Just wanting to know for the benefit of others.
    High Desert SoCal
    02 Honda Civic LX
    hmm...grounding issue... I never thought about that. When I bought my sub, the front power windows didn't work, but when you hit the switch, you could faintly here the motor trying to work. Then, one day, my front passenger window just decided it was going to start working. It's VERY annoying that my front driver doesn't work still though. Please do tell about your grounding issue fun, that might be what's going on with my Sub.
    Christopher
    Apr 2007
    After checking all the fuses I decided to run a hot wire directly from the battery. Still nothing so I got angry and when I did I put the hot wire on the ground side of the switch, and nothing. So I put the wire on the negetive side of the battery and the windows all worked again. The Ground wire coming from the door to the inside of the truck was broken. So I just re-grounded to the inside of the door.
  1. Need fuse panel diagram
    By cary00731 in forum GM Diesel & DuraMax
    Last Post: 03-20-2010, 11:58 AM
  2. Fuse Box Diagram
    By nayanbsb in forum Audio, Video & Gadget Tech
    Last Post: 02-03-2010, 09:11 AM
  3. Fuse Box Diagram
    By mbrown021890 in forum General Chevy & GM Tech Questions
    Last Post: 12-08-2009, 07:11 PM
  4. What fuse is my third brake light fuse?
    By b_burdine in forum General Chevy & GM Tech Questions
    Last Post: 11-04-2009, 07:18 PM
  5. Vacuum diagram
    By timmottesh in forum General Chevy & GM Tech Questions
    Last Post: 09-18-2008, 01:24 PM
