GM Truck Club
Page 2 of 3 FirstFirst 123 Last Post byLast Post by
Results 11 to 20 of 25
  1. #11
    98Hotrod, what Transmission do you Have.....4-speed or 6-Speed??
    MIKE
    99"SILVERADO
    5.3 l 3.73 l G80
    BLACK BEAR CUSTOM TUNE
    SNUGTOP l COLORMATCH l KATZKIN
  2. #12
    Quote Originally Posted by stephan View Post
    It should be on your drivers door label HotRod. It will be the GCVWR, minus the GVWR
    its not for some reason. I've checked like 3 times. the door sticker just shows GAWR and GVWR.
    Owners manual has 5.3/3.73 max trailer at 7700lbs, But it shows 5.3/3.42/tow-haul-pkg at 9500lbs. mine is 5.3/3.73/tow-haul-pkg. My understanding is the 3.73 should give me more than the 3.42, but there doesn't seem to be any data to back that up. So i just been assuming i have as much as the 3.42/tow-haul-pkg.
    Heartbeat: 4spd with tow/haul, more info in my sig.
    2009 Silverado 1500
    5.3L / 3.73 G80 / 4spd / 4x4 / LWB/ Ext Cab / HD Tow-Haul
    2.25in ReadyLift Level Kit / 3in blocks/ 3500lb HellWig / 265x65x17 Wrangler AT
    K&N Filter / AirRaid MIT / MagnaFlow 2.25" Dual Exhaust / HyperTech MaxEnergy
  3. #13
    Legend
    stephan's Avatar
    Sep 2010
    Far West, Oregon USA,
    You're right HotRod. I just went & looked at mine & it's not on there either lol. I forgot that I had to do the math to get the "C"
    1988 Chevy C-3500 2wd (no pic)
    350 c.i. 5.7 L Stock Block, 4 Bolt Mains
    L-31 Vortec Heads, Edelbrock Cam & Intake,
    Holley 650, Flowtech Headers, Magnaflow exh.
    Jet Trans 700R4, B&M Ratchet, 4:10 gears,
    3" susp. lift kit "shadetree"
    No rev limiter, No speed limiter lol
  4. #14
    Jr. Apprentice
    May 2010
    Pittsburgh
    Quote Originally Posted by Crawdaddy View Post
    Yeah, he specced Gross combined vehicle weight and you specced gross vehicle weight. The GCWR is the max weight for both the truck, cargo, and any trailer weight combined. But, that would still only put his GVWR around 5500 pounds.
    GVWR is 7,000lb
    GAWR (both front and back) is 3,950lb
    When I bought the truck (out of state) I had to weigh it to get it registered and it was 5,440lb (can't remember if I was sitting in it or not at the time), but I'm guessing this puts the rear axle weight at around 2,700lb and this would give me about 1,200lbs for the trailer hitch and additional cargo in bed to reach my axle limit so I think I should be ok there. Here are my assumptions:
    5,440 truck
    450 me, wife & 2 kids
    600 hitch
    5,536 trailer dry
    2,000 cargo in truck bed/trailer (don't think actual cargo will be this much)
    14,026
    With the above assumptions I am still under the 15,000 GCWR and I think I'm ok with the rear axle limit and truck wont be over the 7,000 GVWR and total trailer weight is not at 9,500 either. Anyone please speak up if I am missing something...
    Thanks
    ---------- Post added at 09:24 PM ---------- Previous post was at 09:17 PM ----------
    Quote Originally Posted by 99'HEARTBEAT View Post
    Thanks, are you saying I should go with a larger cooler than the K5L option currently on it?
    Its would be something to keep in mind, I also have the Factory Tow package......which includes the Transmission Cooler....and I was seeing Trans. Temps.....around.....180....190.....and sometimes over 200 Degrees when Towing my boat, after replacing the Factory Trans. cooler with the Aftermarket....True Cool 40K Trans. Cooler, I'm now running trans. temps.....at 140...150 Degrees now when Towing my Boat.......a Drop of 40/50 Degrees.....Which is Huge, as Heat is the Single Biggest Killer of Auto Transmission's.....
    Here is my Thread on the install of the the True Cool 40k Cooler,
    http://www.gmtruckclub.com/forum/sho...n-Cooler...WOW
    Edit:...I would add that a Weight Distribution Hitch which will Most likely Come with the Travel trailer would also be a item to have(keep in mind),
    Link,
    http://mrtruck.net/wdh.htm
    Heartbeat, read your links at work today, good stuff but I got a question for you. You say your temp would get 180/190 and sometimes over 200 when towing your boat so I paid attention to my temp guage on my way home tonight and it was right at 210 the entire time, didnt budge. This got me a little nervous so I pulled out my manual and it said that the temp should be at 210 or below (which made me feel better) and I should be concerned if it gets up over 260 when towing, this got me wondering why I am at the levels with normal driving that you are when towing. Think there is any reason for concern for normal driving to be at 210?
    thanks
    ---------- Post added at 09:28 PM ---------- Previous post was at 09:24 PM ----------
    Tony, I think with the WD hitch & anti sway bars on it, you'll have very few problems unless you have real high cross winds. When those are set up right, they tow very straight.
    Thanks that makes me feel better, I have my eye on the equalizer, seems like it will accomplish both WD and sway all in one shot, but I do research everything to death so will prob look at more options out there too.
    Tony - Pittsburgh
    '09 Sierra SLT Crew 5.3L
  5. #15
    thanks
    Tony....before installing the Aftermarket Trans. Cooler, my Trans.Temps were between 140/150 when driving down highway, not towing.....and when towing my temps as I mentioned above between 180 to at times 200.....in the 99" Owners Manual......it expressed that it is Normal for Trans. Temps to have a Operating Range from 100 to about 265.....
    So my Trans. Temps were with-in the range mentioned above, but I was Not Comfortable having my Trans. running at those Temps....so next to installing the Aftermarket Cooler, I've done 2 other Mods/Upgrades to my Transmission.....the 1st was going with Synthetic Transmission Fluid and the 2nd was replacing the Factory Steel Transmission Pan, with a Aluminum Finned Deep Transmission pan, from Mag-Hytec(Link Below).......next to the Aluminum finned also being a deep pan it holds...3-1/3 quarts more than the Factory pan......my Trans Temps dropped to 10 degrees.....to around 180/190......and now with the New Larger Trans. Cooler my Temps have Not gone over 150-Degrees!!.....when towing my Boat......take a look at the Mag-Hytec link below....it has a Chart that shows Transmission Life Relative to Fluid Temperature.
    Mag-Hy-Tec,
    http://www.mag-hytec.com/transmission.htm
    For me installing these aftermarket parts have help with reducing my Transmission Temps......when towing and for me it is peace of mind.
  6. #16
    Jr. Apprentice
    May 2010
    Pittsburgh
    Thanks Heartbeat,
    Have one more rookie question thats confusing to me, when I see a trailer's dry weight (or shipping weight) listed at 5,536 and the hitch weight at 589 (in this example), I was adding these together in my calculation and treating the trailer as being 6,125. Im now starting to question this, does the 5,536 figure already include the hitch weight and perhaps the only reason for listing it separately is to show staying within 10%-15% of trailer weight and for rear axle weight calculation?
    Also, if i am going to be using a weight distribution hitch, do I still need to include the hitch weight in my rear axle calculation or maybe just 50% of it since it will now be spread across both axles?
    Thanks again, you guys have been a great help and I really appreciate it.
  7. #17
    Quote Originally Posted by toleo View Post
    Thanks Heartbeat,
    Tony.....that's not a rookie question that's a Very good question.....I would say that the weight of 6125lbs, as you are adding both of these 2 weights to the load your going to be Towing......
    Below is a Link, that talks about WD and Hitch Weight, this may have the correct answers to your Questions,
    http://www.traveledlanetrailers.com/...ailering1b.htm
  8. #18
    Jr. Apprentice
    May 2010
    Pittsburgh
    I was thinking that too except 589 is only 8.5% of 6125 but its 10.6% of 5536 and puts it in that range, would it make sense that a manufacturer would have a hitch weight outside this range?
  9. #19
    Tony.....the following information is from the 2011" Siverado Owners Manual....The Trailer Tongue Weight (A) should be 10 percent to 15 percent of the.....(Total Loaded Trailer Weight).....up to a Maximum of 600 lbs (272 kg) for the 1500 or 2500 series....
    And up to a maximum of 750 lbs (340 kg) for the 2500 HD or 3500 series with a weight carrying hitch. The trailer tongue weight (A) should be 10 percent to 15 percent of the total loaded trailer weight, up to a maximum of 1,000 lbs (453 kg) for the 1500 series and up to a maximum of 1,500 lbs (680 kg) for the 2500, 2500 HD or 3500 series with a ......(Weight Distributing Hitch).......
    Tony, the way I'm reading the above information......is to get the 10% percent to 15% percent is based off of the .....(Total Loaded Trailer Weight) with a Weight Distributing Hitch.......where does the.....586lbs from Hitch fit in here??.....I'm sorry I don't use a WD Hitch for Towing my Boat.....hopefully one or more of the members who use a WD Hitch will give some insight.
    My question is where does the Weight of the WD Hitch fit In???
  10. #20
    When travel trailers list their total weight, that's the total actual weight of the trailer. The tounge weight usually is around 10% of the total trailer weight. For example, my camper weighs 9000 pounds minus cargo and has a tounge weight of 900 pounds. They way you distribute your cargo in the trailer affects the tounge weight, and of course adds to the total trailer weight.
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 200K miles
    2005 Saturn ION-2 Stock 265K miles
    1982 Bronco, 1993 Bronco (sold), 1971 M35A2 Deuce and a Half
    Remember kids, the only difference between screwing around and science is writing it down- Adam Savage
Similar Threads
  1. Tahoe Used for Towing Travel Trailer
    By Dave1441 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 04-13-2013, 12:40 PM
  2. K1500 or K2500 for towing travel trailer??
    By mcbubrooks in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 04-23-2010, 07:04 PM
  3. How heavy of a travel trailer can I tow?
    By wildbunch in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 03-13-2010, 11:00 PM
  4. Latest mod: 30-foot Travel Trailer
    By Stargazer in forum Chevy Truck Accessories
    Last: 05-26-2009, 12:50 AM
  5. Towing a travel trailer
    By junior2005 in forum The Coffee Shop ~ Chit Chat
    Last: 04-04-2006, 11:31 AM
