GM Truck Club
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    I tow a 28 foot camper behind my '09 1500 (5.3L, 4 speed auto). The camper lists at 8k lbs. I have a weight distributing hitch, and a brake controller, and a sway brake. It still moves around in the wind, but you learn to compensate, especially when big trucks pass. The trans temps reached about 215 on a recent trip, with ambient air temps in the 90 degree range, and engine coolant running over 210, but not 220. That's up and down some major hills, and with a significant load in both the camper and the truck. I'm going to add a better trans cooler. That's a little too hot, for me.
    The worst of it is, my towing MPG runs about 8! The new tires (Goodyear Wrangler MT/R (with Kevlar)) actually cost me about 1 mpg over the factory ATs! Ouch!
    Kevin Singleton '09 Z71 - PA ZRT - kevindsingleton.com
  2. #22
    Quote Originally Posted by kevindsingleton View Post
    Your Camper's.....8,000lbs is that Dry Weight, without Food and Gear......and what Rear Gears do you have??
    MIKE
    99"SILVERADO
    5.3 l 3.73 l G80
    BLACK BEAR CUSTOM TUNE
    SNUGTOP l COLORMATCH l KATZKIN
  3. #23
    Quote Originally Posted by 99'HEARTBEAT View Post
    I'm pretty sure that's wet weight. I'd have to check for details. 3.73? I don't really know.
  4. #24
    If the 8,000lbs is including Supply's.....meaning Food and Gear etc........the Tow Ratings for a.....2009" Ext or Cew Cab 4WD 1/2 Ton with the 5.3 liter W/4L60e and either 3.73 or 4.10 Gears has the Following Tow Ratings,
    .....With 3.73 Gears......Max Tow Rating Weight is......7,500lbs and the GCWR is....13,000lbs
    .....With 4.10 Gears......Max Tow Rating Weight is......8,500lbs and the GCWR is....14,000 lbs
    .....if you have 3.73's.....your over limits of what your Truck can Safely Tow and if you have the 4.10's you are Close to the Limit's of what your Truck can Safely Tow .
    MIKE
    99"SILVERADO
    5.3 l 3.73 l G80
  5. #25
    I knew I was cutting it close.
Similar Threads
  1. Tahoe Used for Towing Travel Trailer
    By Dave1441 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 04-13-2013, 12:40 PM
  2. K1500 or K2500 for towing travel trailer??
    By mcbubrooks in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 04-23-2010, 07:04 PM
  3. How heavy of a travel trailer can I tow?
    By wildbunch in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-13-2010, 11:00 PM
  4. Latest mod: 30-foot Travel Trailer
    By Stargazer in forum Chevy Truck Accessories
    Last Post: 05-26-2009, 12:50 AM
  5. Towing a travel trailer
    By junior2005 in forum The Coffee Shop ~ Chit Chat
    Last Post: 04-04-2006, 11:31 AM
