    Default high idle..what else besides throttle body gasket
    I started by 89 suburban (350) after is sat for a week and it is idling very high probably 2500+rpm (don't have a tach). Never has this before
    popping the gas doesn't bring it down. A vacuum leak would make it idle rough, not high, right?
    I haven't had time to check much, but any other things I should check besides vacuum leaks?
    Any ideas would be great thanks.
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Default Test for a leak
    I wouldn't rule out vacuum leaks. Get out the carb cleaner and spray it around the base of the carb/throttle body and at the intake manifold gasket areas. Some prefer to use propane for this test. I like to take the air cleaner off and cup my hands over the air intake. If as I progressively choke off the airflow the idle normalizes, a vacuum leak is indicated.
    High Desert SoCal
    02 Honda Civic LX
    The idle air control motor could be stuck or the passage could be contaminated. To check, pull the air cleaner assy off, and look at the passenger rear of the throttle body. You'll see a 4-wire square plug sticking out at a 45 degree angle, and a hole inside the throat of the body in that corner. If you plug that hole with your finger, the truck should die. If not, a vacuum leak is your issue.
    Thanks Racer!
    I was wondering where the IAC valve is on these throttle bodies. I will check when I get home. The contamination might be possible becuase I had the air cleaner off while the truck was sitting before this high-idle started.
  1. Replies: 4
    Last Post: 07-25-2010, 10:17 PM
  2. 87 C10 Holley Throttle Body to Edelbrock gasket leaks
    By cyberpine in forum Chevy C/K Truck Forum
    Last Post: 02-04-2010, 04:32 PM
  3. High Idle
    By Chevyguy in forum GM Powertrain
    Last Post: 11-12-2007, 01:58 PM
  4. how to change throttle body gasket
    By 89suburban350 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 07-17-2007, 07:40 AM
  5. idle way high
    Last Post: 07-16-2007, 11:22 PM
