    Default rack and pinion leaking?
    Hey guys, I recently just finished replacing all 4 ball joints on my silverado and outer tie rods, however while my truck was sitting overnight last night, on the drivers side tie rod there was a puddle of black liquid that was leaking from a small cut in the end of the bellow(the dust boot looking thing over the inner tie rod), i checked my power steering fluid and it is full and the color is normal... I dont know what this fluid is... I dont even know if there should be fluid in the bellow or if maybe its water that accumulated overtime and drained out as the tie rod was hanging overnight...
    should i be worried guys?
    thanks!
    2000 Chevrolet Silverado
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    Edge CS insight monitor
    4.10 gears
    Limited-slip differential
    LS-1 Dual Electric fans
    Corvette tranny servo swap
    Audio:
    Head Unit: Alpine
    Subs: 2-12" Kicker CVT's
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    3" Fabtech Spindle Lift Kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
    Powerslot Cryo brake rotors
    EGR in-channel window visors
    If your power steering pump is full and you've never had to add any fluid, I'd say it was probably water, since you mentioned a cut in the bellows. You need to repair or replace that bellows. Water and dirt in there can cause some real nasty problems for you.
    Good Luck and God Bless
    hopefully it is just water... i will try to replace it then... how would i know if the inner tie rod is bad?
    Powertrain:
    Performance:
    Airaid CAI
    Poweraid TB Spacer
    BLACKBEAR TUNED!!!
    4.10 gears
    Audio:
    Head Unit: Alpine
    Tires/Wheels:
    16" PROCOMP 7089's
    Suspension:
    2" leveling kit
    Lighting:
    FRONT
    35W HID Low Beams
    REAR
    Accessories:
    Hawk HPS Brake pads
  1. Pinion seal leaking
    By 02 Heavy Chevy in forum GM Powertrain
    Last Post: 09-01-2010, 01:40 PM
  2. steering rack and pinion assy...
    By Intheneck in forum Lifted & Offroad Suspension
    Last Post: 05-16-2010, 05:53 AM
  3. NNBS rack and pinion bushings
    By canislupis69 in forum General Chevy & GM Tech Questions
    Last Post: 08-06-2009, 02:39 PM
  4. rack and pinion replacement
    By texxx in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-20-2009, 07:11 PM
  5. rack and pinion
    By 07 redrado in forum GM Powertrain
    Last Post: 02-03-2008, 08:36 PM
