Done buy MOOG all the way
I bought cheap upper control arms.. The nut that goes on the ball joint has 3 presses on the end of it making it super hard to turn and not brake the hex tool insert on the bottom of the ball joint shaft. I had to use the ball joint press to hold the ball joint in place while i thighten this through the bottom hole in the press. Other than that easy saturday job.
Side note you do not have to remove the shock and spring to get out the upper control arm bolts out you just have to work at it a little to wiggle them out.
