Results 11 to 20 of 26
Thread: Fuel Problem
    sounds like fuse or relay to me.. You really can't hear the pump run on mine.. when I first got the truck, the pump was going out, it whined REAL loud.. was horrible.. I replaced it, and it now is so quiet you can't hear it.. Got it from 1aauto.com for $98, so if you need one, it's cheap enough to buy a couple.. have a spare.. Anyway, make sure the relay is clicking, by having your buddy or wife/girlfriend, random homless guy, turn the key on while you are under the hood, fuse/relay box open, listening to the fuel pump relay. small grey lower center of box. Wouldn't hurt to swap it with another relay to see if it fires up. they are cheap. check the fuse too, make sure it's good.
    Quote Originally Posted by Tone View Post
    X2....well except the homeless guy....
    Get the Gorilla!
    gorilladip.com
    sales@gorilladip.com
    Jul 2010
    winnetka ca
    Tone.complete modular pump or just the electric pump http://www.autozone.com/autozone/par...ntifier=561140
    Default fuel pump
    The entire assembly. Pump included. Here is the link to the part I got.. Great price compared to $231, which is the cheapest I found locally..
    Apr 2011
    Ogdensburg, New York, United States
    cut factory pluf off to replace with new conector, tested gray and black which are for the pump hooked up test light had friend turn key no light. there is power to the fuel level guage just not the pump motor side
    If yours is wired like mine, I think the next good access point is the relay. Look at the relay to verify that the relay is closing.
    Apr 2011
    Well Still not haveing any luck, no power to the pump new rely and fuse is good does anyone have any more thoughs on this problem
  8. #18
    Wiring diagram if relay and fuse checks out and no power to pump you have lost the circuit somewhere; either a broken wire, loose connector, or a corroded connection.
  9. #19
    Sr. Apprentice Steban's Avatar
    Nov 2008
    san diego, ca
    Looks like now you have to follow the wiring from the pump towards the fuse box and find the broken connection. You should identify which wire is faulty. The power wire or the ground. Check your power wire to the chassis, check for 12v. You could also check continuity from your ground wire to chassisthis will help you identify which wire is giving you the problem. 9 times out of 10 its just a bad ground.
  10. #20
    Apr 2011
    Question chevy silverado 1500 4x4 5.3l fuel problem
    Okay here's an update we have power from relay but no power to relayto tell the relay to close and power pump was wondering what could cause this problem? could it be the ignition switch?
  1. Questioning myself on this fuel problem.
    By aficio400 in forum GM Powertrain
    Last: 11-28-2010, 12:12 PM
  2. 93 suburban tbi fuel problem need help
    By 93 lo'burban in forum GM Powertrain
    Last: 12-27-2009, 08:16 PM
  3. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last: 12-13-2009, 05:38 PM
  4. 97 gmc fuel system problem
    By smokeydabear in forum General Chevy & GM Tech Questions
    Last: 05-03-2009, 05:18 PM
  5. Fuel problem
    By hogger38 in forum Performance & Fuel
    Last: 02-13-2008, 06:24 AM
