Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Fuel Problem
  1. #21
    Assuming your '01 is similar to my '98, the PCM is responsible for telling the relay to close (according to my wiring diagram, it is pin D1 at the PCM). The next step working backwards would be to check the connection between the PCM and the relay and to check if the PCM is sending the signal to the relay to close.
    Working back far enough, the ignition switch is a possibility. Most likely it would be a fault that is blocking power to the PCM. If the PCM doesn't have power, it can't send a signal to the fuel pump relay to close. It also won't be able to tell the injectors to fire and so on. If the PCM is not sending a signal to the fuel pump relay, I would probably check PCM power next.
  2. #22
    Apr 2011
    Ogdensburg, New York, United States
    Well sent it to the dealership so far after three hours they can't figure out why its not starting
  3. #23
    Jul 2010
    winnetka ca
    Default power
    Where is the power coming from if you power out of the relay?
  4. #24
    Default Fuel system parts locator?
    I am not able to start my truck. I am looking first at the fuel system since the motor will turn over. It ran fine before I let it sit for about 5 weeks. I have a relatively "new" 2002 Silverado and need help finding the fuel system parts: Pressure regulator (immediately in front of tank?); fuel pump relay?; fuel line pressure release (black or green cap on rail)? If I press the pressure release valve (looks like tire air valve?) with the ignition key turned on, should gas spray out indicating the system is normally pressurized?
    Also what is the easy way to R/R the fuel filter with out bending the metal lines?
    Thanks for help, siposta
  5. #25
    I had same problem and it was a bad ground
  6. #26
    Jul 2010
    winnetka ca
    Default Starting Problem
    The fuel pressure regulator is above the left valve cover.Pull the vacuum line off. If it is wet replace the regulator.The cover on the fuse panels (2) will tell you what fuse is where. The fuel filter has a hex nut attached to it so you can put a wrench on it while loosing the fuel line
  1. Questioning myself on this fuel problem.
    By aficio400 in forum GM Powertrain
    Last: 11-28-2010, 12:12 PM
  2. 93 suburban tbi fuel problem need help
    By 93 lo'burban in forum GM Powertrain
    Last: 12-27-2009, 08:16 PM
  3. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last: 12-13-2009, 05:38 PM
  4. 97 gmc fuel system problem
    By smokeydabear in forum General Chevy & GM Tech Questions
    Last: 05-03-2009, 05:18 PM
  5. Fuel problem
    By hogger38 in forum Performance & Fuel
    Last: 02-13-2008, 06:24 AM
