Results 1 to 2 of 2
    Default '99 CK Fuel Pump / Filter problem...
    105 actual miles, babied 1999 5.7 4WD. 1500 hlf-ton.
    Coming home the other day after operating perfectly; engine just died and wouldn't restart.
    When I engage the switch, I still hear the pump buzzing.
    Blocked filter?
    Could the pump be defective and still making noises as though operating?
    Something else entirely?
    Thanks in advance,
    Pat
    Maybe to all three questions.
    Standard test for a blocked filter or defective pump at this point would be to test the fuel pressure. If the pressure is normal (~60 psi) and stays normal while trying to start, then a blocked filter/defective pump is not indicated.
    My '98 did something very similar once. Turns out the wires going to the CKP had come out of their harness, laid across the exhaust manifold and burnt through. Diagnosis of this condition started by pulling codes from the computer, which showed a CKP/ICM code. If the fuel pressure test seems to pass, the next thing I'd do would be to pull codes from the computer and see if there are any clues there.
  1. Fuel pump problem?
    By nascar1 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 07-21-2010, 11:19 PM
  2. 305 Fuel Pump Problem
    By Stavrowsky in forum Chevy C/K Truck Forum
    Last: 05-17-2010, 06:23 AM
  3. fuel pump problem
    By kcpshelby in forum General Chevy & GM Tech Questions
    Last: 10-03-2009, 09:35 PM
  4. Intermittent Fuel Pump problem
    By drogers302 in forum Performance & Fuel
    Last: 09-18-2009, 05:48 AM
  5. intermittent fuel pump problem??
    By beachburb96 in forum Performance & Fuel
    Last: 03-27-2009, 05:25 PM
