GM Truck Club
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. #21
    I get exactly what your sayin man. I'm thinking the problem is the Auto Start or Security systems wiring that could be throwing everything off and the BCM is having issues also. I agree with what you said about it not starting because when i turn my key and the dash comes on it has the gold lock indicating the security system is on and the vehicle is locked when in reality it isn't! I'm guessing from what my buddy told me it's throwing everything off and is either electrical or the Computer or both or 1 or the other is throwing either one off. I hope that this is the only problem since i spent a week before i got it towed and made sure everything was fine. I dont have a code reader is why i couldnt find out and i'm not good with electrical on the truck so odds are this is the problem i have.
    I heard you say you dk why the remote start caused the problem i'm guessing isn't there wiring for the remote start? I'm assuming whatever wire was loose or not acting right at the time threw the auto start off and threw a code that it was programmed with but not permanent. My buddy said the auto start is programmed when you install it and somehow it ends up resetting itself and the computer doesn't realize anything since the code changed ha idk it's pretty weird to me though coo dammnn complicated!
    2008 Chevy Silverado Ext. Cab Lt Z71 5.3 V8
    7.5 Inch Rough Country Suspension Lift
    RBP Replica Grille Black w Chrome Rivets
    Recon Smoked Cab Roof Lights
    N-Fab Powdercoated Gloss black Cab Length Nerf Steps
    5% Tint over 20% all the way around / 5% Eyebrow Strip
    AVS Smoked Window Visors
    Z71 Stickers Black & Metallic Silver
    Tow Mirrors / Smoked Turn Signals
    XM Satellite Radio Fin / Color Matched
    Interior Plastic Pieces / Color Matched
    Power Acoustic Tweeters
    Painted Bowties / Color Matched
    Painted Door Handles / Color Matched
    Smittybilt Bull Bar / Color Matched
    Custom Rolled Edge Exhaust Tips / Color Matched
    Custom 2.5 Inch Cat Back True Dual Exhaust
    Flowmaster Super 40 Series Dual in / Dual out
    Magnaflow Tru-X Pipe
    K&N Air Filter
    18x9 Rockstars Machined Black
    Center Caps / Color Matched
    33.13.50 Nitto Terra Grapplers
    New Front Wheel Well Liners
    Eagle Eye Black L.E.D. Tailights
    Eagle Eye Black L.E.D. Third Brake Light / Smoked
    Eagle Eye Black L.E.D. Halo Projector Headlights
    Notto HID Kit 10,000k Low beams
    Recon L.E.D. Light Bar
    Buschwacker OE Style Tailgate Cap
    AMI Gloss Black Antenna
    Debadged Chrome Lettering
    Door Molding Removed
  2. #22
    Master Mechanic zigger215's Avatar
    Sep 2011
    Fairbanks, Alaska
    Sorry for the confusion, yep on an auto start you have all your external wiring that branches out to all your differed circuits. You also have internal wiring in the auto start (tracers on circuit boards) Sometimes you have cold solders on that which could cause some issues. Other times the install looks like it got into a fight with a hand grenade....
    As for the programming, your friend is right, we program all auto starts before they leave the shop (every vehicle is different). BUT there is a second module that needs programmed which work in conjunction with your auto start, it is the module needed to interface with your factory security... Pass lock. That is the module that is more then likely giving you fits if the auto start is indeed the culprit. It also needs programmed and can also lose it's programming and in most cases loses it well before the auto start loses it's programming (which rarely happens but doing things like jump starting a vehicle can cause this).
  3. #23
    Yeah my truck is at the GM dealership getting looked at hopefully today or next few days i will hear back with something that's the problem!
    K&N Air Filter
Similar Threads
  1. Headlight Switch Issue....
    By sstoner911 in forum GM Electrical Tech
    Last Post: 08-18-2011, 07:58 PM
  2. Headlight switch
    By From78to83 in forum General Chevy & GM Tech Questions
    Last Post: 04-21-2011, 01:16 PM
  3. Headlight switch
    By groceryman in forum Audio, Video & Gadget Tech
    Last Post: 04-22-2009, 06:46 PM
  4. automatic headlight switch
    By thejms in forum Audio, Video & Gadget Tech
    Last Post: 02-22-2009, 11:18 PM
  5. Headlight switch
    By 0321 in forum General Chevy & GM Tech Questions
    Last Post: 07-12-2008, 08:47 AM
