    Default Need Help and Quick!!! 90 Chevy Won't Start
    Hey Guys,
    I have a 1990 K1500 4WD 5-Spd. 5.7L TBI. The Truck Won't Start. It is not spraying fuel from the injectors. There is also no power at the injector connectors. I have tested the connectors and the ICM. Both check out. There is battery voltage at the module from the PCM as well as the ICM checked out according to autozone. I expected it would as The entire distributor is new. Not remanned, New from Rock auto. The distributor is 100% new as well as all the parts on it. (pick-up coil, ICM, cap, rotor, etc.) The Coil is fairly new, less than a year. The fuses are good. What else do I need to check or test.
    Check your grounds.
    :cool:
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    you are not getting a signal to the system.Get a set of Noid lights and crank the truck if they pulse..(which they shouldn't) id have to be there to figure it out.
    remember no matter how much crap they throw on these trucks they have to have the basics compression,spark and fuel to run.
    The noid lights will tell you if the injectors are getting a signal if they don't you have lost your reference signal.Find your cam and crank sensor and check them ( do not remember how off the top of my head some use voltage with key on,some use ohm resistance,they will give you a range they should fall into)
    Appreciate the help so far. but got the fuel problem fixed. I had to take the rubber boots off of the connectors for the ICM. That fixed the problem with the fuel. However, the truck is still not starting. I had the coil tested and replaced at AZ and that did not resolve the problem. I am still getting fuel now, but no spark. Still troubleshooting. Any other help would be appreciated. Thanks to all
    Last Post: 02-15-2011, 06:50 PM
  2. Quick pic...
    By mebcop in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 03-12-2010, 10:34 AM
  3. Quick Contest Today - Chevy Camaro Hat.
    By Steve in forum Contests & Giveaways
    Last Post: 08-11-2009, 05:47 PM
  4. Need help quick---plz look
    By MXZ1983 in forum General Chevy & GM Tech Questions
    Last Post: 05-21-2009, 07:17 AM
