    Default 1998 S10 Ext Cab Squeaking from under cab.
    I replaced all my ball joints, and tie rod ends this spring. I am now getting a rubber on rubber sounding squeak. I hit all the fittings with grease again (upper, lower ball joints, tie rod ends, steering grease fittings) is there something I am missing?
    I hear the squeak while driving, turning wheels while stationary, and just entering the truck.
    Any ideas are welcome, Thanks
    1998, 2002 Chevy Blazer 4dr 4wd 4.3l
    1998 S10 Ext cab 2dr 2wd 2.2l
    1988 Chevy R35 "Bucket Truck" 350
    Germantown, Ohio 45327
    murdog94's Avatar
    Take a CLOSE look at the cab mounts, and the rear leaf springs. also the front bushings as well.. it is a 98 S-10 the rubber for the bushings drys out after time as i am sure you know and make fun sounds!
    Mike
    Currently
    2011 F-150 Crew 4X4
    One of the areas I was looking at the lower control arm bushings...any ideas for a temporary fix to alleviate the noise to help isolate the problem?
    Thanks
    murdog94's Avatar
    They make a silicone lubricant spray in a can that works WONDERS!
    I would Check your shock bushings also.
    When I first read your question I was thinking about the heat shield rattleing on the exhaust manifold. But than you said it sounded like rubber on rubber. I would check all that was mentioned before as well as add some lube on the sway bar at the rubber mounting straps.
  1. squeaking noise
    By Runnerboy23 in forum General Chevy & GM Tech Questions
    Last Post: 07-11-2011, 02:38 PM
  2. Squeaking Windows - anyone have a fix??
    By Z71RedRado in forum General Chevy & GM Tech Questions
    Last Post: 10-17-2010, 11:18 PM
  3. Brakes squeaking on my 08!
    By cliff08chevy in forum Lifted & Offroad Suspension
    Last Post: 07-10-2010, 07:28 PM
  4. front end squeaking on an 09!
    By chevymanlobo in forum Lifted & Offroad Suspension
    Last Post: 06-22-2010, 06:38 PM
  5. Squeaking, maybe from suspension?
    By Crakums_GT in forum Lifted & Offroad Suspension
    Last Post: 07-28-2009, 07:30 PM
