    Default Chevy CV Joint Failure???
    I'm driving a 2000 Silverado 1500 4WD. A couple weeks ago I began to notice a vibration and a thumping noise coming from somewhere below the drivers feet. Last saturday I crawled under to inspect, and found play in the front driveshaft forward U-joint and some play at the rear of the shaft near the transfer case. I pulled the shaft and drove to the auto parts store to get a new chevy parts U-joint. The vibration and thumping were gone. I installed the new u-joint and took a test drive. The vibration is gone, but at different times, different speeds, staight or turning, I can hear and feel a pretty heavy thumping. It comes and goes. Sometimes I can just barely hear/feel it...sometimes I swear something is about to snap and the front wheel head off in a different direction.
    So does this sound like a Chevy CV joint failure or something else? and does the slight play in the rear of the forward drive shaft indicate the seals in the transfer case are failing?
    any advice or insight is much appreciated.
    clay
    Chevy Parts
    sounds like a CV to me. I know when they went on my truck the steering wheel would jerk one way or the other. And you usually do hear noise under your feet.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    i agree sounds like cv or diff bearing play---you checked the fluid level and or change it?.........mike
    Michael Collins
    1993 4X4 Suburban
    many other toys as well
    May be CV joint. I would expect a problem with CV joints to be worse in 4wd than 2wd.
    From what I understand, there shouldn't be any side to side/up-down at the t-case. In-out is probably ok, but I'm not sure on your specific t-case model (which t-case do you have?). I know on my Suburban, it's hard to see what's going on at the t-case because of the skid plates and such.
    Are you certain the rest of the suspension is good and tight? Intermittent, seemingly random clunks would seem more related to suspension and steering components (ball joints, tie rods, wheel bearings, sway bar bushings, and so on and so forth).
    Threads merged for double post.
    Question
    iv'e had the steering column "re-lubed" twice, whatever good that does. Seems to eliminate a click in the steering for a while, but that's quite a bit different from this. This is definitely in the front wheel drivers side, and related to tire speed, or rotation of components in the drivetrain.
    I bought a new half-shaft this afternoon. I'll install in the morning, and post if this fixes the problem. If it's the CV joint, problem solved. if not, we'll figure what's next.
    thanks,
    clay
    Cool
    New half shaft installed...problem solved. thanks for the advice.
    clay
    glad we could help!
    Dan
  1. 2001 02 chevy silverado 2500 hd ball joint tie rod ends
    Last Post: 05-19-2010, 10:20 AM
  2. 4 Ball Joint Lower Upper Chevy Silverado 1500 2WD 99-04
    Last Post: 03-25-2010, 06:00 PM
  3. Chevy silverado 1500 hd 01-03 ball joint tie rod pitman
    Last Post: 03-23-2010, 03:10 PM
  4. HELP! 1998 Chevy Tahoe Transmission failure
    By SkeeterG in forum General Chevy & GM Tech Questions
    Last Post: 10-16-2008, 08:52 PM
  5. Failure to service chevy transmission
    By dwill3015 in forum GM Powertrain
    Last Post: 12-06-2007, 10:39 AM
