GM Truck Club
Results 1 to 8 of 8
Thread: 4 wheel drive
    Default 4 wheel drive
    Recently removed all abs systeme now I have no 4X4 tried everything but no go. Any Ideas would be helpfull
    Thanks Big Rick
    Welcome to the club, Rick. Why did you remove your ABS?
    :cool:
    2005 Chevy Silverado Z71 Crew Cab
    6" Skyjacker lift w/Edlebrock dual front remote resoviour shocks, single rear remote. Rancho skid-plate.
    17" x 9" M/T Classic Lock Wheels, 35" BFG A/T or M/T tires
    4.10 PercisionGears w/factory locker, T/A Performance rear-end cover
    Banks CAI intake, ported throttlebody, JBA coated headers, over-sized Magnaflow cats, Magnaflow cat back exhaust, Diablo tuned
    B&M aluminum deep transmission pan
    Warn brush guard w/Warn 9.5 XP winch, PIAA bulbs, Line-X bedliner, AWS Black tool chest, Extang tonneau cover
    Weather Tech floor mats
    Cover-Craft seat covers
    Dash mat cover
    Formula One window tint
    One black Lab in rear seat.
    :glasses:
    Ummmmmmmmmmmmmmmmmm........
    What year/kind of truck?
    Quote Originally Posted by Big Rick View Post
    Thanks Big Rick
    2002 sub modified engine putting out 630hp at wheels with 676lbs torque. original brakes would not stop
    went with 6piston willwoods..
  5. #5
    Understand! Well if the 4wd front axle and transfer case are stock it doesn't matter if the 4x4 works, because with that much HP the 4wd won't last very long!!
    :cool:
    Dash mat cover
    :glasses:
  6. #6
    the transfer case diff drive shafts and trani modified to take it........BIG RICK
  7. #7
    Unless you're holding the gas down while trying to stop, HP and Torque have nothing to do with stopping.
  8. #8
    I am assuming its an auto 4wd, but after fuses you might look into whether or not the push button 4wd relies on the wheel sensors in its engaging.
    David
    2004 Silverado 2500 Crew Cab 4x4, AMSOIL EA air filter, Granatelli MAF sensor, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST) and 4.10 gears, Rhino Liner, EGRUSA fender Flares and widow visors, extended stainless steel brake lines, firestone airbags w/onboard air compressor, Pioneer Avic X940BT navigation, Accel backup camera.
    http://www.gmtruckclub.com/forum/sho...Silverado-2500
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    2013 Toyota Avalon Limited (Wife's Car)
    NRA Life Member
Similar Threads
  1. converting 2 whel drive to 4 wheel drive
    By jdaugherty3 in forum GM Powertrain
    Last Post: 11-24-2013, 07:15 AM
  2. Four Wheel Drive ( when to use it )
    By Alaskan in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-08-2010, 11:30 AM
  3. 4 Wheel Drive
    By crane557 in forum GM Powertrain
    Last Post: 06-22-2009, 11:14 AM
  4. 4 wheel drive
    By andrew bookout in forum Chevy C/K Truck Forum
    Last Post: 03-19-2009, 10:09 PM
  5. FOUR WHEEL DRIVE!
    By Steve in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 03-06-2005, 04:14 PM
