    Sep 2011
    houston texas
    Default crank sesnor/ cam position sensor...
    305 tbi. i know that the crank sensor will throw off the pcm and timing for ignition. if its bad the motor will just roll over? what about the cam position sensor? will it cause the engine to roll over and not start as well?
    Caddiac's Avatar
    May 2011
    Upstate South Carolina
    If the engine is just rolling over and failing to start I would not suspect either of those sensors unless there are other symptoms than what you posted in your thread. If the timing were the problem, I would expect the engine to have been raising hell prior to refusing to start. I do not know about the ODB I used on the TBI but ODB II engines have a DTC that sets the check engine light when the cam shaft and crank shaft sensors do not correlate.
    Do you have any engine codes? What model year and how many miles? What work has been done to the engine recently?
    86 911 Porsche Carrera
    98 K1500 Suburban LT
    2012 Nissan Leaf
    ​General Motors.
    Because life is too short to drive a Ford
    Sep 2011
    houston texas
    89 1500. 305 tbi. no work done to her at all. just moved from south texas to west michigan. got here and it would roll over for a bit before starting if it sat longer than 5 hours or so. then just quit starting. rebuilt the tbi. new fuel psi regulator. fuel pump. filter. cap and rotor. plugs wires. coolant temp sensor. starter. oh and 150k origional miles. so i took the battery to the shop and slow charged it all day at work todat came home and installed the starter and put the battery in and she rolled over a bit and started. i was just unsure about the crank and cam sensor because i had used a scanner form work and had no codes but while i was rolling it over it was not showing me any rpm's. but the test will be if it starts in the morning. thanks and ill reply with more
    Caddiac's Avatar
    May 2011
    Great! I hope that you got her fixed.
    2012 Nissan Leaf
    ​General Motors.
    Sep 2011
    houston texas
    well it was a fluke... but it ran like **** to work and at lunch i got it started after rolling over and over... and i pulled it in the shop and no codes as usual. but then started and drove great after but no start this morning. well anyway long story short i put a ignition coil in and started and drove great.
    Caddiac's Avatar
    May 2011
    Great end to a frustrating story! Thanks for posting the solution for those that come behind you.
    2012 Nissan Leaf
    ​General Motors.
  1. Crank Position Sensor Threaded Insert
    By jmay in forum General Chevy & GM Tech Questions
    Last Post: 10-02-2010, 06:02 PM
  2. CRANK POSITION SENSOR chevrolet SILVERADO 2500 part
    Last Post: 07-20-2010, 02:21 AM
  3. where is my crank position sensor?
    By HI-TORQ in forum GM Powertrain
    Last Post: 05-19-2010, 09:26 PM
  4. CRANK POSITION SENSOR chevrolet SILVERADO 2500 part
    Last Post: 03-23-2010, 07:40 PM
  5. CRANK POSITION SENSOR chevrolet SILVERADO 1500 part
    Last Post: 01-07-2010, 09:00 PM
